Question about Dell Inspiron 8500 Notebook
Dell Inspiron 8500 no lights, no fan, nothing.
After installing a new battery, the laptop died. There is no activity when the power button is pushed. No leds showing on the battery. A check of the power adapter shows 19.5 VDC between the outer and inner rings of the power plug.
Is there a fuse or anything on the motherboard?
  • one_oldbum Jan 26, 2009
    I was afraid that was what I would hear. I guess now it is time to search for a new switch or new board. It was dead even without the battery, but I still wanted to eliminate the possibility that it was possibly the power adapter.
    Problem Solver:
  • 7 Answers
First remove the battery and try it. If it works without the battery, then that is the problem. My Inspiron 2650 suddenly started acting like that with the battery in but works perfectly without the battery.
Whenever you replace a battery ALWAYS let it completely charge BEFORE you try to use the computer with the battery in place.
Do the POWER, DISK ACTIVITY and/or BATTERY CHARGING light stay on?
If so try powering the computer off; unplug the power cord; remove the battery; carefully remove the RAM modules; check the connections for corrosion/dirt; them reinsert the modules; close up the case; plug the power cord in and try powering it up without the battery inserted to further eliminate the battery as the problem.
If you get NO lights or fan noise without the battery installed, you probably have a mother board problem, most likely in the power switch. With the 2650s the switch is an integral part of the motherboard (DELL calls them system boards I believe) and DELL recommends replacing the board. I guess if you can find someone brave enough to work on the board, you could fix the switch because DELL refurbishes them and if the board isn’t working anyway, then you have nothing to loose.
I hope this helps you. Good luck. The 8500s are good computers if you get enough memory in them.
Don Jones
Posted on Jan 26, 2009
Dell inspiron N7010 wot't turn on.
call tech support and get a complete diagnostics done.
Feb 19, 2014 | Dell Inspiron N7010-JQ02DN1 17R Laptop PC...
I just got this Dell Inspiron 1100 laptop used from Ebay that arrived on Thur Aug 15th. I installed my DDR memory and my 250gb ide hard drive. The laptop fired right up. And I installed XP Pro. ...
XP Pro! Now there*s your problem Mythbusters would say. Hence its going to become obsolete of security service after 4/2014, its not that MS is going to make it easy to install "new bastardo ones" into the system...
Aug 17, 2013 | Dell Inspiron 1100 Notebook
DELL INSPIRON M5030 frusturating issue (tried almost everything)
A) How did the Power Button Module get broken?
B) Error indicates losing data and unable to leave Hibernation Mode.
It's a long shot, but let's see if you can reset BIOS Settings back to default, without being able to see the BIOS Setup screen.....
Remove the AC adapter (Charger)
Remove the Battery.
Remove the RTC Battery. (Real Time Clock. Same as CMOS Battery, but with a new name)
Oh, excuse me.....Dell = Coin-Cell Battery
Power Button Module flat flex cable installed in motherboard connector, press the Power On button, hold it down for a count of 10 seconds. Let go.
Do this same procedure two more times.
Reinstall Coin-Cell Battery
Reassemble laptop.
Reinstall Battery, THEN AC adapter, and THEN plug AC adapter into power.
Let's see if we can revert the BIOS Setup settings, back to the factory default settings.
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-15-m5030_service%20manual_en-us.pdf
C) Dell refuses to help you since your warranty expired.
Not sticking up for Dell, but Really?
You're telling me they're not going to take your laptop, and fix it for a specific amount of money?
"No thank you Mr.Robertson, we're a laptop manufacturer, and money is of no consequence!"
We get by just knowing people out there like our laptops.
That, food stamps and the occasional barbecue Gates puts on at his place, gets us by."
Right.
Did you know I'm Brad Pitt? Angelina is in one of her moods again, so I come on here.
(Just trying to be funny)
D) LED lights 2 & 3 stay on
LED 2 is the Harddrive Activity LED.
Should stay solid as the harddrive isn't active
LED 3 is the Battery Status LED.
Solid amber indicates ON, or Standby.
Did you follow Anti-Static Procedures, during the Power Button Module replacement?
Plus, I'm willing to bet the Power Button Module, didn't come from Dell. Another reason they would not want to work on the laptop.
They can't guarantee the replacement part is good.
(They can, but there are too many liability issues)
Power Button Module being broken, is what I'm concentrating on at the moment.
This was the start of the problem. From it all other problems have issued.
The Power On switch is a Momentary Contact Switch.
The carbon contact Power On switch on that Power Button Module.
http://www.parts-people.com/index.php?action=item&id=9908
Was it broken so it stayed pressed to the on position?
Also need to know the full extent of damage caused by the Power Button Module being broken.
In my estimate it took a pretty hard hit in that area, to break that board.
Lastly for now; The Power Button Module has a FFC.
Flat Flex Cable.
Is it replaced back in the SAME position? Not flipped over?
It will go in either way. Right side up, or flipped over.
Please post back in a Comment.
Regards,
joecoolvette
Mar 13, 2013 | Dell Inspiron 1300 Notebook
Inspiron 1521 will not power up
I'd say that you have exhausted your options. You can try to isolate the power on problem by removing your your memory modules, hard disk drive and see if it at least stays powered on. Here is a link from Dell for your laptop's manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1521_Owner%27s%20Manual_en-us.pdf
Feb 09, 2013 | Dell Inspiron 1521 Notebook
My dell Inspiron 1420 will not power on. when the power button is pushed the power light comes on for about 3-5 seconds followed by the battery light for about 1 second and thats it. nothing else comes on...
a dell inspiron 1420 is a laptop you have put it under printers
im assuming your talking about a laptop
try charging your laptop or turning it on with the charger still attched to the laptop
if laptop does not turn on with the charger attached then either that the battery is dead and you need a new one or your laptop itself is gone
Dec 30, 2009 | Office Equipment & Supplies
Dell Inspiron 8500 new batteries installed not acknowledged.
THE SWITCH IN THE BATTARY COPARTMENT HOT ALLOWING THE BATTERY TO CHARGE OR BE RECONGNISED THAT A BATTERY IS INSTALLED, THERE IS NO WAY THAT YOU HAVE TO BATTERIES WITH THE SAME PROBLEM, THE RELAY SWITCH THAT SHUTS DOWN THE POWER FROM THE WALL INORDER TO CHARGE THE BATTERY IS THE PROBLEM, IT MAYBE SOFTWARE DRIVEN BUT I REALLY THINK IT IS A SOFTWARE ISSUE, HARDWARE AND A SWITCH THE POWER CONNECTION TO THE BATTERY CONVERT IS IN OPT OR NOT WORKING PROPERLY. I DONT HAVE THE RIGHT TERMINOLOGY, BUT SOMEONE SHOULD BE ABLE TO HELP YOU RESOLVE THAT ISSUE THE GEEKS AT BEST BUY, OR STAPLES IF THE HAVE A TECHN ON SITE, FRYS ELECTRONIC, EGGHEAD SERVICE CENTER, EVEN WHERE YOU BOUGHT IT SHOULD HELP YOU RESOLVE THIS BIG PROBLEM.
ROD
Feb 10, 2009 | Dell Inspiron 8500 Notebook
Dell inspiron 8500
Sounds like the incorrect RAM (SUPPORTS PC2100 AND PC2700 DDR SDRAM SODIMMs) for that laptop. Also try re-seating the RAM in the socket and that is not installed backwards (hard to do , but I've seen it)
Nov 04, 2007 | Dell Inspiron 8500 Notebook
Open Questions:
See all Dell Inspiron 8500 Notebook Questions
Dell Inspiron 8500 Notebook Logo
496 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
