Question about EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express
LED connectors i`m trying to locate the pins for the power LED on the elitegroup 945g m3 system board
    Problem Solver:
  • 4 Answers
The LED pins should be on the front panel header.  See page 12 of the manual which can be downloaded from
Posted on Jan 25, 2009
Send me a copy link dosn't work for me somehow
i'll help from there
Posted on Apr 29, 2011
Hi e machine upgrade to core 2 duo 3gig mem nvdia8600gt 1gig cpu runs hot with nvdia tried paste on both uninstalled onboard graphics 945g or should i leave installed what is the best nvdia driver for fan...
What are you using to monitor your nvdia8600gt board?
What temperature are your reading at idol?
What temperature are you reading at full load?
Are you using stock cooling unit on the video card?
Jan 03, 2011 | EliteGroup 945G-M3 Motherboard
Is e intel core 2 duo e6550 compatible with 945g-m3
Yes this motherboard is compatible with the Intel Core 2 Duo E6550 processor since the maximum processor support of this motherboard is core 2 duo LGA775 Socket so everything should be fine between these motherboard and processor.
Oct 02, 2010 | EliteGroup 945G-M3 Motherboard
I have Elite group 945g-m3 motherboard and DELUX DLC-MD302 Midi Tower case and just can`t connect the front audio pannel because the connectors on the case are different from what the diagram in the manual...
If it is different then probably it cannot be connected to your motherboard but if it have the same count of pins then it will be ok to put it on. Don't worry if you improperly connect it, it will not burn out, its just won't work.
Oct 11, 2009 | EliteGroup 945G-M3 Motherboard
What RAM options for Elite Group 945g-m3 motherboard available?
Hiya Prodigalrich
the maximum you can put in this board is 2gb = 2 x 1gb sticks of speeds ddr2400/533 and 667 running in dual channel mode
hope this is of use
Feb 27, 2009 | EliteGroup 945G-M3 Motherboard
Ecs 945g-m3 motherboard power switch pin location????????
I have found the manual for your motherboard, here is a link to the download from the manufacturers website.
I hope this helps,
Thanks for using FixYa,
Jan 21, 2009 | EliteGroup 945G-M3 Motherboard
Where are the EliteGroup nForce3-A power & reset plug-ins located at?
Goto page 10 in your user manual. There look for. Connect the case switches and indicator LEDs to the SW1. (Location).
There is mother board layout decription for how to connect the case, 2-pin wires case connectors ( Page 12 shows pin numbers & which is plus + & negative - pins.). You'll nee the manual to help you. Download it from ECS at:
Aug 12, 2008 | EliteGroup nForce3-A Motherboard
Motherboard not working correctly.
The way that I solved the problem was to unhook each and every connection to the motherboard except for the 4-pin and 24-pin power supply connections, the processor, the cpu fan and the power on switch connectors, once I have done that, then I plugged in the power supply and turned it on, in which that worked! After that, I would hook everything up to the motherboard one piece at a time, in which after each piece I would turn the power supply on again to see if that was the problem. Starting with the hard drive, the memory sticks and then the DVD drive, and found out that was the problem. The cable between the DVD drive and motherboard was the wrong cable for that motherboard. I will purchase a new cable and see if that works!
Apr 21, 2008 | EliteGroup 945G-M3 (V1.0b) (945GM310B)...
ECS 945G-M3 PC build problems
Reading your manual:
On page 23, In bios, select 'advanced' menu item from top, then second option below should be 'OnBoard VGA Share Memory' - set to 64MB.
Jan 13, 2008 | EliteGroup 945G-M3 Motherboard
EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
487 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
