Question about Hunter Dryers
Hunter fan reciever part 85483-01
Can I find a remplacement receiver with reverse motion to match my ceiling fan
clyde2j2
  • 137 Answers
SOURCE: Light not working-hunter ceiling fan need part number 85112-01?
"Google" ----"replacement parts for ceiling fans"
there are dozens of sites that may be of help.
Posted on Mar 02, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
  • 34 Answers
SOURCE: HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Posted on Sep 10, 2009
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
Try Cheyenne Lamps 2000 E. 17th Street Little Rock AR
501-374-2829
Posted on Dec 24, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
How do I repair a Hunter Ceiling Fan thats blades won't spin?
The remote receiver could have failed partially so only light control works.
May 26, 2015 | Hunter Dryers
Lights come on at random .has a remote how to fix ?
The fan remote control receiver used in the Hunter 25730 model fan (see picture) is not available from Hunter. Remove the fan from the ceiling. Remove the receiver and take it to recycling. It can be replaced using a readily available and inexpensive replacement universal remote and receiver controller. There are limitations though. The Hunter receiver provided fan reversing functions. The universal controllers do not. You therefore have two options.
Option 1: The universal receiver can be installed such that the fan direction is fixed, either up or down, all other functions operate normally.
Option 2: A reversing switch can be purchased from Radio Shack for about $4 and installed in the fan. This does require cutting a square hole and drilling two bolt or rivet holes in the side of the cylindrical housing which previously housed the Hunter receiver. I'd suggest the Radio Shack DPDT slide switch part number 275-403.
Refer to the wiring diagrams and connector pinout diagram for connections. Please note that the connector pinout diagram is the connector that is soldered to the circuit board as shown in the photo of the Hunter receiver. If your motor wire colors are different then with the connector unplugged from the receiver use a multimeter to probe all the motor wires in order to identify two pairs of wires that indicate approximately 70 ohms each pair. These will be the motor windings. 6b0a1409-5a20-4efe-a059-c600652e9512.jpg 5da8e4ef-1b54-40d0-a8a4-21d4608b1d23.jpg 9fc8772d-3ac3-41b7-aa55-78ccc6e5ea00.jpg 0759e340-6464-4c4b-90f5-6d9926e74e42.jpg
Jan 23, 2014 | Hunter Ceiling Fan Light Remote Control
Bought new remote& reciever,how to install it
What model of fan do you have? It's a 5 digit number starting with a 2.
Jul 23, 2013 | Hunter Ceiling Fan Remote Receiver...
Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
May 17, 2011 | Hunter Ceiling Fan Remote Receiver...
Receiver 85112-04 need a replacement for hunter fan remote receiver which is housed in the based of the fan in ceiling.
I realize that this is an old post. However, the best solution is to replace the receiver with 3 or 4 speed wire harness, which includes the capacitor, fan speed switch, forward/reverse switch and female plug for $15 as of today's writing. While you may be able to find a 85112-04 replacement receiver, I found them to be an expensive solution at $80. In addition, there is no telling how long the replacement receiver would last. To purchase a 4 speed wire harness for this Hunter fan, they can be ordered from
Casablanca. Casablanca you say? Yes! Casablanca is a subsidiary of Hunter Fans. This 4 speed wire harness, part number K016501H01, is standard in many Hunter and Casablanca fans. Hopefully this will help someone looking for a low-cost solution to replacing the fan. Link below:
http://www.casablancafanco.com/Parts-Manuals/Part-Manual-Detail?ModelNumber=54019
Apr 11, 2010 | Hunter Ceiling Fan Remote Receiver...
Im installing a hunter remote control receiver in the ceiling mount. I have a red, black, white and ground wire from the ceiling. Which wire on the reciever do I connect the red wire to?
The red wire in the ceiling is probably used in a shared neutral circuit and not needed for the fan. If it's not capped off already, it should be.
Just use black, white and ground from the ceiling.
Charlie
Aug 16, 2009 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay Redington IV ceiling fan remote won't work
the reciever is under the cover for your fan to the ceiling. Try pulling the switches on you fan then using the remote after each try. then check your wall switches,,, it could be wired to one.
Aug 16, 2009 | Hunter 28156 Cote 54' d'AzurĀ® Ceiling Fan
Dryers Logo
52 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
