Question about Indesit Washing Machines
Iwdc 6105 wiring diagram - Indesit Washing Machines
2 Suggested Answers
  • 6277 Answers
SOURCE: Hi I have a indesit
It's possibly a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 14, 2011
My washer/dryer model iwdc 6125 will not dry clothes properly they come out hot steaming and wet its only a year old
Check the vent hose for lint build up. If it goes into a wall, be sure there is no obstruction. The dryer has a flow sensor that detects a reduction in airflow out the vent hose. It will shut off the heat to prevent a vent fire.
Oct 24, 2016 | Washing Machines
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
I'm looking for a manual for a Singer sewing
Go to the singer website, they have a free PDF download
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 6105 ) & click search
Sep 22, 2011 | Singer Sewing Machines
Should the Indesit IWDC 6105 washer dryer give off a burning type odour when running the drying cycle. (it is brand new and condenser)
I have seen some new dryers give off a smell for the first few seconds that they are run for the first time.
If it's any longer then that is not normal.
Aug 02, 2011 | Dryers
Hi I have a indesit IWDC 6105 washer dryer. problem with door lock light. as soon a wash starts light goes off and wash stops and the door unlocks
John C
Jul 14, 2011 | Washing Machines
My Sherwood RD-6105 shuts off if I turn it up past 28 or 29 db (which isn't very loud). I'm using it in Dolby Digital mode. It even happens when I use it with my components that are analog. This just...
It's acting as if a short or near-short exists on the amp outputs at medium levels.
Disconnect one of your speakers at a time and try it. Make sure your speaker wires are tight and not shorting to anything and all channels have 6-ohms or more load.
Jan 16, 2011 | Sherwood RD-6105 Receiver
I have a Singer 6105.
Take the top off and you can slacken the screws on the windewr and move it over slightly, if that does not work you will probably need a new winder rubber
Mar 06, 2010 | Sewing Machines
How to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
Jan 28, 2010 | Cooper Wiring Devices Motion Sensing...
Washing Machines Logo
54 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
