Question about Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black
Water won't come through my nespresso machine
I started my nespresso and it ran out of water. I put more water in but now nothing is coming out and I don't know what to do. Please help!
5 Suggested Answers
SOURCE: water leaks from the top of the C190 Espresso Machine
in our case the problem was fixed easily: the metal piece in which the capsule sits is screwed in on the top. When it became loose our machine started to leak water from the top. So the problem was solved by retightening it!
Posted on Feb 02, 2009
SOURCE: Nespresso Essenza C100 leaks all the water out
I have a nespresso type D90 which does exactly the same thing so it is probably not just yours
Posted on Feb 09, 2010
  • 21 Answers
SOURCE: Nespresso Essenza - water is not coming out of the spout
Try...Hit the start button then Lift the lever and push back as far as possible and hold for 3 seconds. hit stop button, then close lever. this should restart machine.
Posted on May 08, 2010
  • 21 Answers
SOURCE: water not coming through nozzle of nespresso essenza
I have had this issue. I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
Magimix M190 CITZ
Are you using genuine nespresso capsules? Are they seating properly. Open the slot where you put the capsule in and check its very clean and nothing is stuck in there.
Have you tried resetting to factory settings?
Apr 03, 2014 | Nespresso D300 Espresso Machine
I have a Nespresso Lattisima and all four lights are blinking four times in quick succession and nothing is working. I've tried emptying it out and it's done that, but still the same problem.
Your machine has almost certainly entered the water quality mode. (Water hardness setting). This is very easy to fix. Switch machine off. Before switching back on press and hold any off the following buttons: Latte Macchaito (top right) for soft water, Cappuccino (bottom right) for medium water or finally both of them for hard water. While holding the correct buttons switch the machine back on BUT hold for approx. 10 seconds or until all lights stop flashing, (APART FROM THE BUTTON YOUR HOLDING). This will reset the machine and you're good to go. Regards Coffee Engineer!
Jan 17, 2013 | Nespresso Lattissima 660.R
Nespresso not making any noise, water not coming out
return it to place of purchase as defective w/ receipt
Oct 06, 2017 | Krups Nespresso Citiz And Milk
Nespresso citiz won['t exit descaling mode
I had the same issue, and took it to the repair shop, where the guy did the same thing, just pressed both cup buttons for 3 seconds. It worked. He said the Lungo button had to be pressed a little harder, as it had some connection problem, and thats why it didnt work for me. If you have the same problem, the machine will start buzzing for about half a sec if you press the lungo button while in descaling mode.
Nov 29, 2012 | Nespresso Citiz C110
Why do Nespresso capsules squash?
the capsule must plop in at an angle, it it's straight it will crush and not work properly
Apr 18, 2012 | Coffee Makers & Espresso Machines
Le Cube: Water does not flow after tank in Le cube ran dry....
Open the lever (the one on top of where you put the pod, and keep pressing it backwards until water comes...
May 18, 2010 | Nespresso Le Cube
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black Logo
613 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
