Question about Zmodo PKD-DK4216-500GB 4 CH CCTV Security DVR IR Camera System 500GB
Zmodo PKD-DK4216-500GB default admin password
Cameras flashing between infrared (night) and NO SIGNAL - 1 is off (4 total)
Sounds like you have a power supply problem in the DVR, get your installer to check it
Jul 30, 2014 | DMCOM Zmodo Pkd-dk4216-500gb Complete 4...
Zmodo default password
The user name is ADMIN (All upper case)
Password is 1234
Jul 28, 2013 | Home Security
Zmoda "no root"
You will need to contact Zmodo. It is most likely a corrupt password. You maybe able to access your menu, but wont be able to do anything and will get the "no root" error message. They will verify you are the actual owner via either your registration or a number off your orig invoice, for security reasons. (You could be a crook trying to delete the evidence, its good they check) They will then give you a bypass admin code to put in, then direct you to change your password and you should be all set. I just got done doing this after waiting for an hr with their online LIVE chat, and finally just called and waited the 15 mins for someone to answer. Its a small shop, but, they were friendly, knowledgeable and most important, spoke REAL ENGLISH!! =]) I spoke with Tony and after I got it fixed, he gave me a case number which will allow me not to have to go through all the verification next time around if I give it to him.. so, find your invoice and place that case number on it for future reference and put it in a handy location you wont forget.
Hope this helps the 20 plus ppl I found also asking pretty much the same question. I looked all over the net and I am an IT Professional and I couldn't find an answer.. even on their website. I plan on adding the answer there too as well. Have a GREAT DAY! =])
Jan 08, 2013 | OEM Systems Zmodo Surveillance...
Forgot password zmodo h.264
Is there a reset button? or try 0000-or-9999-or-1234
Aug 22, 2012 | Zmodo 8 Channel H.264 Surveillance...
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 08, 2011 | Belkin (F5D8231-4) Wireless Router...
Wanted to set password om my linksys
192.168.2.1
192.168.1.1
Sep 07, 2011 | Computers & Internet
New password wifi
Sep 07, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
How 2 put the password?
Sep 07, 2011 | SMC Barricade N Wireless Broadband Router...
Forgot my password and cannot reset?
Sep 06, 2011 | Computers & Internet
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Mikw
Nov 05, 2010 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Zmodo PKD-DK4216-500GB 4 CH CCTV Security DVR IR Camera System 500GB Logo
155 people viewed this question
Top Zmodo Computers & Internet Experts
David Payne
David Payne
Are you a Zmodo Computer and Internet Expert? Answer questions, earn points and help others
