Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a 15 HP. Sears Lawn Tractor with a standard transmission.
I can't get the clutch and brake adjusted the way they need to be to operate the tractor. I have never changed the drive belt. Is there some special way to adjust the clutch and brake screws so these things work properly? If I pull back on the clutch when I put it in gear it does work but that is a pain. Can I get a manual on these adjustments? How hard is it to change the drive belt?
  • richardawhit Mar 14, 2009
    I have the same problem, I have an LT200 with automatic transmission. I have multiple problems I need to adjust (tightnen) all of my cables. I would also like to know how to adjust the blade engage/ dissengage cable. Thanks Richard
  • Mark Tripp
    Mark Tripp May 11, 2010
    What is the model # and Serial # of your machine?
  • 69 Answers
SOURCE: looking for owners manual sears 15.5hp craftsman
Look here...
http://www.managemyhome.com/mmh/prod...Display.action
Posted on May 18, 2009
  • 376 Answers
SOURCE: need to adjust brake/clutch 14hp craftsman lawn tractor
The brake is on the right side of the transaxle. There are two mounting bolts and one 1/2 nut in the middle that is your adjustment. Tighten it 1/2 turn at a time and hold the brake down and try to roll it until it holds.
Posted on Jun 09, 2009
  • 138 Answers
SOURCE: craftsman 42 in 19.5 unable to control speed forward motion
is this perhaps a hydro trans? if so, try putting the shift lever in neutral, then let off the brake pedal, use the shift lever to go forward and to neutral to stop - same with reverse, don't even use the brake pedal except for emergency stops. if it's a manual shift, it's possible the belt is incorrect, and/or the belt guides are bent or the belt is improperly routed - the belt guides are important as they allow the belt to "blossom" off the engine pulley, reducing the "shock" load when engaged - hope this helps
Posted on Aug 17, 2009
SOURCE: need to replace a clutch cable
i need a picture or explanation, how does the clutch spring attach
Posted on Aug 28, 2009
mowerman1857
  • 389 Answers
SOURCE: Sears lawn tractor tubeless tire replacement
Most local tire shops have or can get tires and tubes of the size you want/need and would install them as well. Without the proper tools, they can be a "bear" to change but if you insist upon doing it yourself, go to a GOOD lawnmower repair shop and have them order the sizes for you. It has been my experience though, the tire shops are cheaper
Posted on Sep 14, 2009
Craftsman Lawn Tractor 17hp 42 model 917.271662 auto trans idles and bucks when cutting grass
The symptom that you are feeling is that your transmission is not fully engaging correctly. Basically you have a few different things to try depending on the trans that is on your machine. Drain the fluid and re-install new fluid, adjust your brake/clutch to make sure that you are fully disengaged and fully engaged when you release the pedal. If none of those 2 cure your issue then you are looking at a trans rebuild or replacement
May 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hydro trans slips on dyt4000 craftsman
I'm having the same problem on a 200 and have narrowed it down to belt slippage. Problem is I replaced both pulley's and belt with Sears parts and made it worse. You can pull back on the brake/clutch pedal and it doesn't slip but there is no adjustment I can find. ANYONE got a CLUE
Apr 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to fix gears on riding lawn mower
First: check your drive belt. Don't have the product manual? Download it from the Sears or Murray website. Second: Check your clutch/brake linkage. The clutch may need adjustment. Procedure on manual. The clutch wears over time and needs to be readjusted.
Nov 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need to adjust brake/clutch 14hp craftsman lawn tractor
Jun 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears tractor mower gearshift stuck or hard to shift
If this is a standard shift transmission, try rocking the mower back and forth. May be in a bind. If not, look underneath mower and find where shift linkage goes into transmission and try to move by hand.
May 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need to replace a clutch cable
Apr 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Troy Bilt Horse Lawn Tractor Transmission problems
you need to screw the transmision adjustment in so that it is push all the way in to gear.
Apr 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
