Question about Motorola Mobility ROKR E8 Cellular Phone
E8 ROKR recognized at my PC as camera and scanner
I think my usb connection cable has a problem. Every time I plug the cable and I check in My Computer....camera and scanner? inside of it are empty no folders or anything.. cannot even copy a file and some weird settings on its properties. Like "Test Camera and Copy pictures etc.."   My appologies I'm a new user to Motorola i usually had no problem with Sony Ericson mobile phones frequently having problems with Nokia phones..please need your help and suggestions thank you in advance..
  • trustdevil Feb 16, 2009
    em havin d same prob
    its of no use
    i guess we needa reinstall d xp again no other option
From your phone go to the main menu(select the following) - settings - connections (usb setting- memory card). thats all you need to know for transfering pics music ect. then plug in your usb and it will read every file you are trying to get ahold of
Posted on May 21, 2009
I have the same problem after i reinstalled my winXP, and i could not figure it out how to fix it. But, if you just want to just put musics into the phone, then i have a way to do it. You can simply drag the music files or folders straight into the phone internal hdrive. first, from your phone go to the main menu(select the following) - settings - connections (usb setting- memory card). Connects to yours computer and it should came up as two mass storage (one is your memory card and the other one is the internal drive). if you want to put music files into your phone just double click on the phone internal drive, and drag or copy yours music files into the MUSIC folder. I hope it helps.
Posted on Feb 05, 2009
Trying to copy photos to a folder using Microsoft Scanner & Camera Wizard. Camara is on and is connected to my PC with a USB cable, but the computer can not detect the camara.
First, check both ends of the USB cable to be sure that the ports and the plugs are properly seated so that the metal pins are able to transfer data. Restart Windows with the cables plugged in, and the camera should be recognized. You also MUST have the camera turned ON in order for the computer to read the fact that it is connected. If these suggestions fail, check your Microsoft Computer Management program to be sure that PlugnPlay devices are automatically recognized by your system.
Have fun with your photography!
Sciencewoman
Mar 31, 2011 | Samsung SL202 Digital Camera
How do i copy files from my handset to pc
Hello ,
Using a USB cable you can easily connect your Motorola ROKER E8 to your PC and do the data transfer to and fro.
For that you need a USB cable and a Motorola driver.
Steps to follow :
1) Download the driver and install it on your PC.
2) Using data cable connect your cellular phone to the PC and start doing the data transfer.
Download Motorola 4.9.0 Driver with MotoHelper
* You can also charge your mobile using this.
Feb 19, 2011 | Motorola Mobility ROKR E8 Cellular Phone
How to connect motrola rocker e6 with laptop
Down load the software and install into the PC , use the connection cord to link and connect. If the phone is detected directly the software is not required.
try this link for help:
www.motorola-rokr-e8-software.soft-java.com/???index.html
www.phone.mobile9.com/i/motorola+rokr+e8
Sep 28, 2010 | Motorola Mobility ROKR E8 Cellular Phone
Want to copy my messages from moto rokr E8 to my pc... Plz tel me how to do it ??
Hi,what to need:
Usb cable and the drivers to install the usb cable.
Or Pc suite.(software112.com/products/motorola-pc-suite.html)Use this link to download the PC suite.
Before you connect the usb cable,install the drivers first before connecting usb cable.
After installing the drivers,connect the cable to phone before connecting to the PC.
You can access the messages from the Pc suite and you can copy out the messages through the Pc suite.
If you are having problems after these process, please fill free to write your comment.
Take care.
Sep 26, 2010 | Motorola Mobility ROKR E8 Cellular Phone
My motorola rokr e8 wont charge with usb cable on my computer
hi...
To charge your mobile with usb cable you should install a driver called as mobile phone usb driver ,if you install it you can charge your mobile through PC.
If still it doesnt charges then install the PC CHARGING DRIVER.
I will give you the website which contains the driver and the instruction below it to install the driver so that you can charge your mobile by usb
website : http://www.motorola.com/consumers/v/index.jsp?vgnextoid=3fd11e8c04021210VgnVCM1000008406b00aRCRD
thanx
Jul 19, 2010 | Motorola Mobility ROKR E8 Cellular Phone
My pc doesn't recognized my cp e8
establish usb connection while on media player
Jul 21, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Moto rokr e8
To drag and drop music, photos, and videos between your PC and phone
Select Settings (or Office Tools > Settings) > Connections > USB Setting > Memory Card. Connect the USB cable to phone and PC. Open phone or memory card removable disk (PC: My Computer; Mac: desktop). Drag and drop files between PC and phone or memory card. When finished, safely disconnect disk (PC: use Safely Remove Hardware; Mac: drag removable disk to trash). Unplug USB cable.
These are the steps. You just drag & drop. If you need clarification on any of the steps don't hesitate to ask me. If this helps plz rate this for me. Thank you kindly.
Feb 01, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Facing problem with usb of motorockr e8 ?
There are two type of portsin USB enabled PC one is Type USB1 & Second is Type USB2. USB2 is faster and is compatible with most new devices. most of the flash drives when attached to USB1 prompt a message to attach to USB2 port to work faster. I am using E6 & it works fine with my Laptop & Desktop. So plug the cable into a different USB.
Jan 03, 2009 | Motorola Mobility ROKR E6 Smartphone
My Computer cannot detect USB device for my ROKR E8
Sometimes it pays to uninstall programme and then reinstall programe.
Dec 18, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Moto ROKR E8 not showin in safely remove hardware
It just doesn't show, but there's nothing to worry, u can unplug it like that, it won't hurt the phone or ur PC
Dec 04, 2008 | Motorola Mobility MOTOROKR E6
Motorola Mobility ROKR E8 Cellular Phone Logo
233 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
