Question about HP 14" EliteBook 8470p B5P22UT Laptop PC with Intel Core i5-3210M
Hp 8470 calibrate battery - HP 14" EliteBook 8470p B5P22UT Laptop PC with Intel Core i5-3210M
How do I disable the mouse pad on elitebook 8470
Hi just double hit on the little hole on the upper left of the touch pad. This one will light orange when disabled. Regards.
May 27, 2014 | HP EliteBook 8470p Notebook
601 error message
Hello.
I am sorry that you are experiencing this error message. It generally indicates that your measured storage capacity in your primary battery is less than 25%. What this means is that your primary battery (601 indicates that it's primary) can only keep a 25% charge. To keep this quite simple for you, please attempt the following.
* Unplug your power cord.
1.) Start up your Laptop and hit the ESC key immediately.
2.) Press F2 to get into Systems Diagnostics.
3.) Select Battery Test. * Now, plug in the power cord.
4.) Start Battery Test.
The battery test will give you a STATUS. If you see the following;
- Calibrate: This means that your battery is functioning correctly but it is in need of calibration. Select the automatic calibration option.
- Weak: From here, please get a new battery to ensure that your getting adequate power supply to your laptop for use.
- Replace: Replace the battery.
- No Battery: If there is, indeed, a battery inserted. Remove it, check for dust/dirt and wipe it clear. Insert the battery and see if it works now.
- Unknown: Try to download all available updates from HP Support Assistant.
Feb 09, 2013 | HP Pavilion ze2000 Notebook
The battery is fully charged and loses the charge within 15 minutes of being fully charged. Battery is 18 months old!!!!! Help
Simple fix turn on the puter on the logo screen press F10 to go into bios setup page scroll over to battery calibration on the tabs on top you will see HDD and Battery choose battery.
Now hit calibrate.
1- Recharge
2- Discharge
2- Recharge
Let the puter complete all of the sessions without interruptions.
That will calibrate your battery to charge correctly. thanks.
Nov 07, 2010 | HP Compaq Evo n610c Notebook
Battery calibration soft ware
Below is the link where you can go and download the software for Battery calibration software for your HP Pavillion X155 Pc Notebook.
CLICK HERE to download
Please let me know if you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Pavilion xt155 Notebook
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
System diagnostics says needs battery calibration
battery calibration is nothing but it the process to discharge the battery fully.
discharge the battery fully till the system gets off automatically, then only recharge the battery for 100%. make this process for 3times continously
Dec 24, 2009 | HP Pavilion dv1000 Notebook
Hp compaq nx9010
try and unplug the battery and see what happens when you try to switch it on the external power source.
Oct 20, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
HP 14" EliteBook 8470p B5P22UT Laptop PC with Intel Core i5-3210M Logo
70 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
