Question about Apple iPod nano
While syncronizing my apple nano ipod with my pc my ipod was hanged
  • 342 Answers
Do you mean the iPod was snagged with the USB cable? Is it frozen now? And have you already attempted to reset it? If not I have posted a step by step on resetting an ipod just in case you need the information still. I see that your issue was posted a while ago. Maybe its already resolved?
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Posted on May 14, 2009
Ipod nano 4th gen was diconnected from itunes without being ejected and ipod has frozen
Press the top button and the home button (on/off switch) at the same time for about 7 seconds.
Until you see the Apple logo.
Then let your Ipod initialize and syncronize as normal.
This will hopefully help you.
Jun 24, 2011 | Apple Audio Players & Recorders
My nano apple ipod is hanged
Reset iPod nano (if it isn’t responding) Slide the Hold switch to HOLD and back again. Press the Menu and Center buttons at the same time for about 6 seconds, until the Apple logo appears.
Mar 07, 2010 | Apple iPod nano
Hanging of apple ipod
Please note that to use the iTunes sync and the Nano itself, you will need to meet the minimum specs for your PC. So if you don't meet that spec for your product, you will cause a critical failure on your PC. And if your computer is old or is lacking the requirments then you should:
1. Sync a small amount at a time.
2. Upgrade your computer to meet the minimum requirements, (and if you do meet the minimum know that only means that you can sync and it isn't saying you will definately sync)
You should meet at least the optimum spec requirments otherwise you will crash the computer or lock up the Nano.
3. If you haven't already install the Nano's software into the PC, then download all needed updates before syncing.
-Luke
P.S. Please post one problem to your issue, not multiple with similar issues worded differently or worded wrong, or just mis-typed.
Jan 25, 2009 | Apple iPod nano
Hanging or apple ipod
Reboot the Nano by Pressing the Menu and Center (Select) together and holding until the screen goes blank. Then let go when you see the Apple logo appear.
That should help.
If that still doesn't then you will have to reset the nano to factory by using the iTunes iPod utility in the iTunes program.
-Luke
Hi i have iPod nano (gray) 8 gb mp4/wma/rec/amv. i don't know how to use it i didn't recieve any instructions with it and i don't know how to use the itunes website. can you send me the instructions for...
Hi! You want to use itunes website to buy songs and games or you want to use itunes for syncronizing your songs in ipod. If you want to add songs and other stuff to your ipod then download the itunes from http://www.apple.com/itunes/download/ and install it. After installing the ipod connect the ipod with the computer.
After connecting the ipod with the PC it will automatically detect your ipod. And then add your favourite songs to your ipod by dragging them into the library or by importing them into library from file tab.
Dec 23, 2008 | Apple iPod nano 3rd Generation
Apple ipod hang
Try resetting it by toggling the hold switch and putting it back in the off position. Then press and hold the center button and the menu button for about 6 seconds until the ipod goes off and the Apple logo appears. After that, it should work like new. Hope this helps.
Oct 06, 2008 | Apple iPod nano
Ipod was ejected without clicking on icon. Now it wont syncronize and says it's disabled
Press and hold the center button while holding down on the menu button. Youi will see the apple logo. Your Ipod is now rebooted.
Aug 25, 2008 | Apple iPod nano
Ipod nano 3rd generation 8gb hang when connect to computer
http://serviceman.site88.net/index_files/Apple_Ipod.htm
Jul 02, 2008 | Apple iPod nano
Problem on ipod
Don't forget to create a new sync profile for the now-empty iPod.
See also David Pogue's articles on the this stuff.
Jun 27, 2008 | Apple iPod nano
My ipod has hanged
have you tried holding down, the menu and center key for 30 seconds. and also go to apple's website, they have a pretty good guide on unfreezing iPods.
Oct 01, 2007 | Apple iPod nano
Apple iPod nano Logo
48 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
