Water tap closed led illuminated also FH in time remaining
Just bought secondhand whirlpool 5763/5 washer after 5 mins the water tap closed led illuminated and FH displayed in time remaining window. the water taps are turned on please help
Traced the fault to the cold water valve solenoid not operating so pleased to say that the person that sold me the washer has now given me my money back
regards paul
Posted on Jan 26, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
My Whirlpool Duet washer is making a loud squealing noise when filling with cold water, or it reduces the cold water to a trickle, which sometimes causes the washer to throw an FH code. It does not h
Hi. Got some info about the FH error from Whirlool service manual.
F/H
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
In my experience the CCU is the problem (control board).
IF the machine has water! If not, check water valve, hose, water tap.
Do it overfill? If thats the case, the pressure switch is gone, its hose has a leak.
Hope this helps you
Sep 27, 2014 | Whirlpool GHW9400 Duet Washer
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    Whirlpool duet washer fills with water washes for about 12 min then code hf
    The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
    http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
    GENE
    Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool front loader AWM6145/3 1450 RPM DURING THE WASH HAS COME UP WITH FH. WHAT DOES THIS MEAN PLEASE
    'FH' for whirlpool washers decodes as 'no water inlet'.
    If you have checked that both hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both of the water inlet filters. Turn the taps off and remove the water hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace them and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve or malfunctioning control board. Sorry but it needs a service call to confirm ;-0(
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck,
    John C
    Apr 20, 2011 | Whirlpool Washing Machines
    My whirlpool washer stops and the water tap closed light comes on, plus on the time remaining FH comes on
    the hot water tap has to be on aswell because it picks up the outside temperature and if its too cold it will ask for a squirt of hot water because the water has to be at a certain temp to react with the detergents properly just this model that does it
    Jan 05, 2011 | Washing Machines
    Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
    Telephone: Fax: VAT Registration No.:
    Infrared remote control
    NOTE: Infrared emitter can be seen at front edge of key.
    System operation
    Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
    Programming
    When
    Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
    How
    Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
    NOTE: LED illuminates for approximately 5 seconds.
    Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
    NOTE: A maximum of 4 keys can be programmed. Fig. 1
    Radio frequency remote control
    System operation
    Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
    Programming
    When
    How
    Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
    Aug 25, 2010 | Ford Focus Cars & Trucks
    The machine displays FH, what does this mean?
    "FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
    Thank you !!
    Jul 02, 2010 | Whirlpool AWM8143 Front Load Washer
    Whirlpool washer duet
    The FH means water tap closed. If you were happy with using cold only you could get a Y-piece connector and join both the red and blue inlet hose to the cold tap.
    Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool awm 8125/3 fault code FH
    Probably too late, but here it goes:
    FH means some cicle is taking too long time.
    Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
    Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
    Feb 07, 2009 | Whirlpool AWM8123 Front Load Washer
    Washing Machines Logo
    718 people viewed this question
    Top Washing Machines Experts
