Question about Honda Garden
HONDA F506 CULTAVATOR RUNNING FULL THROTTLE
MY HONDA F506 FOUR STROKE CULTAVATOR IS RUNNING FULL THROTTLE, STRIPPED CARB COULD NOT FIND ANY PROBLEM, MOVING THROTTLE LEVER MAKES NO DIFFERANCE. ANY HELP WOULD BE APPRECIATED JOHN
Git-R-Dun
  • 6 Answers
SOURCE: I have a 1997 Triumph Legend, with approx 2200
If it is backfiring on deacceleration you have a fuel mixture problem and need to "sync" the carbs.
Sync Pro carb tuner works well. This is a precise four channel vacuum indicator designed specifically for intake synchronization of engines with multiple carburetors or throttle bodies.
Also, if you have not done so, check your plug wires for defects and resistors, if your wires have them.
Good luck, hope this helps.
Posted on Mar 16, 2009
  • 48 Answers
SOURCE: will only run with full choke and absolutely no throttle.
Carbs gummed up. Need a serious cleaning or a full ruubers replacement/rebuild kit. Gas turns to gummy when left stting in the fuel bowls.
Use a couple of cans of Sea Foam.. best stuff in the world.
Posted on Mar 20, 2009
  • 3567 Answers
SOURCE: honda 1300c backfire through carb at wide open
Try balancing ans syncronising the carbs.
BALANCE THE CARBS
Turn the throttle screw on the LEFT carb one half turn inward. Now start the engine and get it warmed up. With the engine running, remove the RIGHT spark plug wire. Adjust the idle speed on the left carb to the point where the engine just can't quite stay running and dies. Now put the loose spark plug wire back into place.
Now turn the throttle screw on the RIGHT carb one half turn inward. Restart and rev the engine. Next, remove the LEFT spark plug wire. Adjust the idle speed on the right carb to the point where the engine just can't quite stay running and dies. Now put the loose spark plug wire back into place.
Turn the idle screw on each carb EXACTLY ONE QUARTER turn outward and restart the engine. The engine will be probably be idling very fast. Adjust both the idle screws equally from this point to get to the desired idle speed.
SYNCHRONIZE THE CARBS
Remove the air filter and rubber fittings to allow you to see into the throat of both carbs. You may need a mirror to see inside. You need to be able to see the slides go up and down when you twist the throttle. Now turn the fitting where the cable goes into each carb such that there is just a bit of slack in the cable, 1/16" is plenty. Lock ONE of the cable adjusters down tight. All further adjustments will be made on the other carb.
With the motor turned off twist the throttle very slowly while looking at the slides. Both slides need to begin lifting at the exact same moment. If the slides don't raise at the exact same time then slowly twist the throttle until the locked adjuster slide just barely starts to move. Hold the throttle still and turn the adjuster on the other carb so that the slide on that carb just barely starts to move also. Now recheck the slide movement timing. Do this process until the slides on both carbs begin to raise at the EXACT same moment. Lock down the loose adjuster and re-check the slides.
Please rate this solution. Thanks!
Posted on Mar 30, 2009
  • 10 Answers
SOURCE: I have a 85 Honda Shadow vt 500. Engine is surging
did you clean all the jets good sounds like it may be in the jets and needle part of the carbs
Posted on May 07, 2009
  • 311 Answers
SOURCE: when I start my 1998 honda xr80r it revs to near full throttle
it sounds to me like the throttle slide has been installed incorrectly,unscrew the throttle housing off the top of the carb(it looks like a cap and the throttle cable goes through it)remove the throttle slide from the housing,down one side of the throttle slide there is a piece cut out that goes the whole length of the slide (lookes like a groove),inside the carb body there is a small brass knob,this groove or cutout goes over the knob and it stops the throotle slide from rotating,once you have installed the slide back in the carb the slide should drop right to the bottom of the housing,you can check this by looking through the rear of the carb and you should be able to see the bottom of the throttle slide,if the slide is installed incorectly the little brass knob stops the throttle slide dropping to the bottom of the housing and will give full throttle,its an easy fix and wont take more than 10mins to repair,hope this helps
Posted on Jul 10, 2009
2003 KTM EXC 250 hard to start. Heavy kicking full throttle choke closed finally starts. 4 stroke. Revs high then low and dies what do I need?
That sounds like a loose hose or bolts between the carb and the cylinder. Classic symptoms of hard starting, revving and dies. If not that, strip and clean the carb.
Dec 12, 2016 | KTM Motorcycles
Model ut10522b chainsaw runs at full speed when warm and will not throttle back
You have an intake air leak. Engines need fuel and air to run, ignition timing also helps for four strokes. I assume that your chainsaw is a two stroke. You have fuel, it is getting air from somewhere past the throttle plate.
Sep 04, 2016 | Garden
Full throttle
check when its on full throttle that the carb butterfly is at 90deg and not over as this will reduce throttle but max advance on ignition !
Feb 11, 2014 | Seloc Mercury Outboard Engine Repair...
My 2002 Honda CR250 is hard to start. Sometimes it just won't kick over. Is this a common problem with 2002 2 stroke Honda's?
My 02 starts like a charm but I found that one or two kicks with throttle closed then one good kick as I crack the throttle seems to be the solution when it is cranky. If you continue to have problems I suspect the pilot jet is clogged. It has the smallest hole and if the bike sits it will gum up first. Open the carb and look for the jet up inside a hidden recess beside the main jet. You will need a narrow screwdriver. Make sure you get a good fit so you don't strip the soft brass jet. Clean with a wire and blast carb cleaner up into the place where the jet goes. While you have it open check the float and needle seat to make sure they are clean and move smooth.Good luck.
Dec 28, 2010 | 2002 Honda CR 250 R
My chain saw will not start. I gave it to a guy who messed up the carb adjustments. Need to know the initial carb setting.
Turn both jet screws CW to stops (lightly), then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on. Turn the H needle CW until the engine starts to speed up, but still 4-strokes. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle so that the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jul 11, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Hi, on a poulan Titanium chain saw, what is the carb ajustment? Thanks Douglas Neil
Turn both jet screws CW to stops (lightly), then back both out 1-1/2 turns CCW each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on--the engine should 4-stroke. Adjust the H needle CW until the engine speeds up somewhat, but continues to 4-stroke. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW until the engine runs fairly well, but still allows the engine to 'follow-the-throttle'. Adjust idle speed so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hi i have a viyality 50 2 stroke issue is wh...
its still a carb fault!!! but its a blocked running jet
so strip out the carb and clean out all the jets
dont go poking wire into any of the jets as you will only distroy them that way,,,use carb cleaner and comprest air if you can check you have a good flow of gas getting through the carb then re-fit the card and run the engine up then tune it when warmed up
May 20, 2010 | Motorcycles
Carb adjustments/ rule of thumb
Assuming that the adjustment screws 'H' and 'L' have slotted heads, turn both CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed-up, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine keeps running.
May 21, 2010 | Husqvarna Chain Saw 20" Bar
I have a 1997 Triumph Legend, with approx 2200 miles when bought it had been stood for 8 years. would run under 45000 rpm's managed to get it home carried out full service and stripped carbs found pilot...
Mar 08, 2009 | 2000 Triumph Legend TT
Garden Logo
46 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
