Question about Apple iPod nano
Hanging of apple ipod
Apple ipod is hanged while syncronizing wid the pc
  • 21 Answers
Please note that to use the iTunes sync and the Nano itself, you will need to meet the minimum specs for your PC. So if you don't meet that spec for your product, you will cause a critical failure on your PC. And if your computer is old or is lacking the requirments then you should:
1. Sync a small amount at a time.
2. Upgrade your computer to meet the minimum requirements, (and if you do meet the minimum know that only means that you can sync and it isn't saying you will definately sync)
You should meet at least the optimum spec requirments otherwise you will crash the computer or lock up the Nano.
3. If you haven't already install the Nano's software into the PC, then download all needed updates before syncing.
-Luke
P.S. Please post one problem to your issue, not multiple with similar issues worded differently or worded wrong, or just mis-typed.
Posted on Feb 12, 2009
I pod Hanged...
if you have an Apple logo stuck on the screen) try the following sequence of steps:
  • Hold down Select / Menu (to reboot the iPod)
  • As soon as the Apple logo appears, hold down Rewind / Select until...
  • ...you see a backwards Apple Logo.
  • At this point, you will have entered Diagnostic Mode. It'll test the RAM, and then tell you to HIT PLAY TO CONTINUE. Hit 'Play'.
  • You'll be in a menu that you advance by hitting FF (Fast Forward). Advance to the 'DISKMODE' entry.
  • Hit 'Select.' This will put you into Firewire Disk mode. The screen should change to the familiar 'Do Not Disconnect' mode. At this point, connect it to the computer.
  • Run the restore utility; it should now recognize the iPod and offer to Restore the factory software. Do so. You'll lose whatever's on it, but you'll avoid having to send it back in to Apple and pay them $49 or whatever to do basically the same thing. :-)
Jul 09, 2009 | Apple iPod MA446LL/A MP3 Player
WHEN I CONNECT TO PC MY APPLE IPOD HANG UP
Reconnect ipod to pc..After ipod says connected in computer remove hardware click on ipod..wen says safe to remove hard ware look on ipod to it saying disconnecting..Afetr full disconnecting push and hold pause/play button down for more than 5to 10 seconds..Should work properly..
Apr 04, 2009 | Apple iPod MA446LL/A MP3 Player
Hanging or apple ipod
Reboot the Nano by Pressing the Menu and Center (Select) together and holding until the screen goes blank. Then let go when you see the Apple logo appear.
That should help.
If that still doesn't then you will have to reset the nano to factory by using the iTunes iPod utility in the iTunes program.
-Luke
Jan 25, 2009 | Apple iPod nano
Apple ipod hang
Try resetting it by toggling the hold switch and putting it back in the off position. Then press and hold the center button and the menu button for about 6 seconds until the ipod goes off and the Apple logo appears. After that, it should work like new. Hope this helps.
Oct 06, 2008 | Apple iPod nano
My apple ipod is hanged when i connected to computer
try performing a soft reset before connecting to the computer and then connect to pc...!!!
Thankyou
Feb 18, 2008 | Apple iPod MA446LL/A MP3 Player
Problem downloading videos on ipod model no. A1137 EMC no. 2066
which ear-phones,datacable & usb charger can be used for apple i-pod (model no.A1137)EMC NO. 2066
Jan 06, 2008 | Apple iPod nano
Apple ipod
you can try to do a manual reset on the device...most likely you might have to replace the device...
Jan 03, 2008 | Apple iPod nano
Apple ipod
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
My ipod has hanged
have you tried holding down, the menu and center key for 30 seconds. and also go to apple's website, they have a pretty good guide on unfreezing iPods.
Oct 01, 2007 | Apple iPod nano
Apple iPod nano Logo
65 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
