Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Chage lamp on Pt-43lc14-K
Where is the lamp located?
    Scholar:
  • 73 Answers
On the front, under the screen there is a large plastic cover. The far right side of the cover has the black decals "HDTV 1080i" and "VIVA bb3 sound" on it. There aren't any screws holding it on, just pressure snaps. Pull the sides of it off gently and the three or so foot long panel will come loose. You'll see a black plastic panel now with two doors, one in the middle and one on the left of the middle door. The one on the left has a white lamp warning label decal and a black screw holding it in place. Remove the screw and take off the door. Inside is the lamp housing. Some models have a a screw on the right side of the black plastic housing, holding it in place. Take out that screw and pull the housing directly out toward you. You now have the lamp housing. If you are replacing it with a new lamp and housing just push the new on into place and reassemble, you're all done. If you are replacing just the lamp, you have a little more disasembling to do. But its not hard. If you need further help, post a comment and I'll send pictures. Good Luck.
Posted on Jan 25, 2009
  • GSBN Jun 09, 2011
    Unfortunately, the screw holding the lamp housing is stripped, I guess, because after turning and turning, it doesn't come out. I'm not sure what to do. Do I get needle nose pliers and force it out? What other suggestions might be helpful in removing the screw.
I am not able to take out the lamp from the housing what should I do
Posted on May 28, 2011
Cant take the lamp from the housing..plese help
Posted on Aug 22, 2009
  • 1 more comment
  • Farishtaaziz May 28, 2011
    How do I take out the old lamp n replace the new one just the lamp
    Nit able to take out the lamp from housing
    I want replace only the lamp plz help
Reset lamp timer panasonic tv
PT-43LC14/PT-50LC14/PT-60LC14.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down SPLIT PLAY button on the remote until a message appears on the screen that the lamp timer has been reset.
Good luck
Note: I got it from here: http://www.dlplampguide.com/tyla1000.html
Dec 13, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I need lamp for panasonic model no.
bigspareswarehouse have a full range and they are a bit dearer then others but it will last for a couple of years as the cheaper ones last about a year if that, hope this helped
Apr 27, 2010 | Televison & Video
Resetting the lamp timer for my Panasonic
You need the original remote to reset the lamp. Try to find a neighbor with a similar tv or buy one off ebay.
Mar 05, 2010 | Panasonic PT-43LC14 43" Rear Projection...
How do i reset lamp hour meter
Turn On tv.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
This will reset lamp timer in Panasonic PT-43LC14
When the lamp time reset procedure is complete, the Lamp Time is Reset screen will appear.
Thanks.
Feb 05, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Pt-43lc14
To reset the Lamp timer back to zero
simultaneously press the "down split channel" button on the bottom of the remote and the down volume on the TV for 5 seconds or more. You will get a message on the screen that the time has been reset to zero.
May 22, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Need to reset the lamp timer / Panasonic PT-43LC14
hold the volume down on the TV and press and hold down the MUTE button on the remote control. Be sure to hold both buttons down at the same time and until the red light goes out.
This worked for me.
Mar 16, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Can't remove screw on lamp cover panel PT-43LC14
Using a phillips head screw driver, you need to grip the unit with your left hand and then push really hard against the screw head before starting to turn the screw. They are very tight from the factory. Once it breaks loose and starts to unscrew, the rest is easy.
Feb 27, 2009 | Panasonic PT-43LC14 43" Rear Projection...
TV WONT TURN ON
I found the problem with my set! I pulled out the lamp to inspect and low and behold the filiment was burned out. Just ordered a new lamp to replace it. That should fix it.Very easy to pull the lamp .
Dec 11, 2008 | Panasonic PT-43LC14 43" Rear Projection...
LAMP REPLACEMENT
lamp replacement on this set is through the front of the unit... the bottom front panel is removed to acess the lamp door. Place your fingertips under the front cover and pull it from the display. there will be a lamp cover door with a screw to remove. then you will have to loosen the screws in the lamp and pull the lamp out
Feb 22, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
825 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
