Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Ge fridge not cooling
I assume this model is close to mine. Mine is gss25lgmabb. Compressor hot to the touch. Put kick start on and comp. ran lock roter amps. removed kick start and cmpressor ran, condensor fan was running as well as evaporater fan but i had no cooling at all in freezer or refrig. All coils are clean. Could the comp. be going off and on? Ther arnt any ports to check refrigerant level. The display for the temp. settings in the refrig. department are not on. I checked the capacitor it test good. does this model have the start assist on the side of the comp?
  • tracy harris Jul 30, 2007
    I did find a leak in the evap coil. I replaced coil charged the systemby weighing in the required 4.5 oz. of 134-a refrigerant. Still there is no cooling at all. What should be the equalized pressure be and the running pressure. Found no sign of a restiction, compressor is hot to the touch.
    Novelist:
  • 159 Answers
Are you sure that the compressor is running? If it is and you have no cooling it sounds like you have a leak in the system and there is no gas left. Most refrigerators have a 5 year warrenty on the sealed system. If you fall into the 5 years you may want to call GE. also there is a electronic control bord that comtrols the unit that could also be defective causing the compressor not to start. Good Luck hand hope this helped you some.
Posted on Jul 13, 2007
SOURCE:
I have a GE GMR04HASCS Compact Refrigerator.
Refrigerators do not react well to being carted around in any position but upright.
Oct 29, 2017 | GE GMR04HASCS Compact Top Freezer...
My refrigerator stopped cooling, but I still have power and lights, however, my digital cooling settings are no longer lit. Is it possible my board is bad and how do I go about fixing this problem, or can...
check back side of your fridge touch the motor compressor running or not if not running check the electronics board and make voltage check from electronics board to motor compressor. if the compressor running touch the one side of copper tube if have hot one side. if have hot your freon ok check the cooling fan inside the freezer side ok good lock
Jan 01, 2010 | Refrigerators
Will not cool,will not freeze. compressor will not kick on.
you can try a hard start kit(has a big start capacitor but if it was mine i would replace it)
Aug 13, 2009 | Whirlpool ED5FTGX Side by Side...
Refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Nov 04, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Dec 31, 2007 | Refrigerators
COMPRESSOR TRY's TO KICK ON BUT SHUTS's OFF
My GE Refrigerator is not reaching a cool temperature the compressor was very hot so we let it cool to try to reboot it but it has not done anything, the refrigerator has the freezer at the bottom , has the compressor gone or could it be low on freon
Dec 02, 2007 | GE J Series 18.2 cu. ft. Top Freezer...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Fridge temp high
freon and a compressor is about as easy as it gets....Loss of freon will cause erratic cooling...also if you can feel it touch the compressor after it shuts off if if feels like its really hot ....bad compressor that kicks an internal breaker....bad news then time for new one also only a airconditioner man can put freon in no 12 . but freon will stay for 50 to 80 years for i tested some old fridges and still cool fine.
Aug 31, 2007 | Avanti 310SST Compact Refrigerator
Freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Aug 20, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
251 people viewed this question
Top Refrigerators Experts
Brad Goodale
Jeff sanchez
Level 1 Expert
Peter Taylor
