Question about Makita 9901 3 inch x 21 inch Belt Sander with Dust Collection, 1246 SFPM, 6.7 Amps
Makita belt sander overheated seized - Makita 9901 3 inch x 21 inch Belt Sander with Dust Collection, 1246 SFPM, 6.7 Amps
rowdy45176
  • 2176 Answers
SOURCE: slipping belt
OK the belt tensioning mechanism is spring loaded. First what is the quality of the belts are they real flimsy or stiff. You say the rollers spin but my question does the rear roller still spin and the belt remain stationary. If so the rubber belt on motor is bad. I would take a look for excessive wear on the rear roller. Does the yoke mechanism snap forward or move slowly, look for a build up of sawdust in this area that might be restricting movement on the yoke. The wear plate in still good condition. One other thing on the belts are they directional? Do they have an arrow on the inside if so that has to point toward front of tool. I looked at a breakdown and could not see anything else to suggest. I never had this problem except with belts when I was at Makita.
Posted on Jan 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: The belts on my Makita 9304 belt sander are wearing unevenly
check the wear plate on the bottom and also check the front roller for being out of round is where I would start. Let me know if doesnt help
Posted on Feb 18, 2009
  • 10865 Answers
SOURCE: Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
Posted on May 02, 2009
  • 384 Answers
SOURCE: Unable to remove dust bag
Get your wife to help you remove bag. Turn and pull.
Posted on Jul 22, 2009
pst4911
  • 41 Answers
SOURCE: my makita 4"X24" sander makes
http://www.ereplacementparts.com/makita-9404-belt-sander-parts-c-97_103_535.html
I would say you have a bearing going out ether on the motor this web address will take you to a good break down of the housing I would say you need a motor bearing it will also give you a parts # but if you have a bearing supplier somewhere ( I look in yellow pages for electrical motor repair) you might find the bearing for a cheaper price just remember to take the old one with you so you are sure to get the same size. I have found bearing and belts for my table saws are the same as for some clothes washers for about 1/2 the price as ordering from sears
good luck
Pat
Posted on Oct 29, 2010
I have a Makita belt sander,just replaced belt tensioner system including springs and roller but belt drive roller still keeps stopping on relatively light load even though the motor is running
very good trade tool
how quickly is it getting hot
slowing motor could be the cause
motor bushes and bearings can be replaced
did the motor drive belt under the cover get replaced
Jun 02, 2016 | Makita 9911 Compact Lightweight 3" X 18"...
My makita 4"X24" sander makes
good luck
Pat
Oct 29, 2010 | Makita 9404 4'' x 24'' Belt Sander
Belt will not tighten small round spring come loose do not no where it goes
Usually there is a knob with a screw imbedded with a spring around it that screws in and adjusts the "tracking" of the belt so it doesn't run off the side of the rollers. If you lose that screw, then teh belt will come off quickly.
At this site, look at part # 68, 69, and 70
http://www.ereplacementparts.com/makita-9403-belt-sander-parts-c-97_103_113.html?osCsid=l052ctaa4vsu2817buk99qpop2
Jan 15, 2010 | Makita 9404 4'' x 24'' Belt Sander
New rubber drive for makita 100 mm belt sander were can i get one
WENT TO RUBBERMAN IN GEORGE AND FOR R20.00 THEY REPLACED THE RUBBER ON THE DRIVE WHEEL-BEATS PAQYING THE THOUSANDS FOR IMPORTED SPARES.G
Dec 27, 2009 | Makita 9404 4'' x 24'' Belt Sander
May 02, 2009 | Makita 9404 4'' x 24'' Belt Sander
Feb 17, 2009 | Makita 9404 4'' x 24'' Belt Sander
Makita 5010 will not work in random orbital mode
It sounds like the bearing in thee bottom plate is seizing. If you turn the pad by hand does the motor turn. It should be smooth. I would look at that. The bearing number for Makita is 211236-8 or if you can get a generic bearing it is 6002DDW. Let me know
Jan 11, 2009 | Makita Tools & Hardware - Others
Looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Dec 26, 2008 | Tools & Hardware - Others
Makita 9901 3 inch x 21 inch Belt Sander with Dust Collection, 1246 SFPM, 6.7 Amps Logo
43 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
