Question about Heartland 3530 Dual Fuel (Electric and Gas) Kitchen Range
We own a Heartland Legacy 3520 since 2003 and need to replace the burner knobs, but haven't been able to find them anywhere. Do you know where we might find them?
The part number indicated in the manual is 35761. Our complete model number is 3520-CPGO200 (P might be a D).
I'm looking a thermostat oven burner for my heartland gas range 9000 model or someone who can rebuild an existing part?
I think you will need to buy the oven burner assembly that includes the thermocouple (thermostat). Refer diagram on page 31 in the manual at this site.
http://www.heartlandapp.com/media/242493/classic_gas_installation_and__operating_instructions.pdf
The part number is available on page 38 and it also has the contact details for Heartland.
Sep 23, 2014 | Kitchen Ranges
Smell gas from one of the burners when stove is not in use
If standing pilot, make sure the pilot is lit. If not standing pilot, the gas valve is leaking (it is attached to the knob and shaft you hold to turn).
Replace the burner valve. Be sure to indicate which one, eg., Left front, right front LF, RF,..
Oct 23, 2013 | Heartland 421001WB06LP Dual Fuel Kitchen...
Adjusting front (most powerful) burner on kitchenaid (Left front)
There is an air port near the adjustment knob. Open for a more blue flame and close for a yellow flame. If these haven't been moved before, you probably have a clogged jet at the burner. Just clean it out with a pin.
Feb 04, 2012 | KitchenAid Blenders
Heartland legacy dual fuel
You can try calling the vendor, but since you aren't the original owner of the range you are probably out of luck. I would scrap it and be glad you didn't set your house on fire or give someone food poisoning.
Jan 05, 2012 | Heartland 3530 Dual Fuel (Electric and...
The brass valve "stem" that the plastic
Although this grills is no longer available, Coleman may still support it. Try contacting their Customer Support Dept 800-835-3278, if you haven't already. From what the Owner's Manual shows, what you're needing is the entire burner valve assembly. As the brass stem is not a separate part.
I hope this helped and thanks for choosing FixYa.
Aug 04, 2011 | Coleman 9995B750 Grill
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
I turned on hot water to take a bath, and it was hot. by the time the tub had filled the water was freezing. now we cant seem to get hot water out of anywhere. the pilot light is on. the knob is set to on,...
if I was a betting may I would say that this is a small water heater, what is the temperature set on, as the pilot light will be lit once the temperature is reached, but until then the burners will be lit. I would move the temperature knob and listen to see if I hear the burners kick on. Hope this helps Tim
Apr 17, 2011 | Heating & Cooling
The oven door of my heartland stove does not close tightly any more. Is there an easy fix?
i have a 36 in legacy when you replace the door oven strip do not put it on the bottom
Jan 31, 2011 | Heartland 3525SS Dual Fuel (Electric and...
Heartland 3530 Dual Fuel (Electric and Gas) Kitchen Range Logo
91 people viewed this question
Top Heartland Kitchen Ranges Experts
Dan Webster
Dan Webster
Tom Chichester
Are you a Heartland Kitchen Range Expert? Answer questions, earn points and help others
