Question about Canon F152800 Faxphone L90 Fax/copy/printer Machine With Toner
Canon F152800 Faxphone L90 Fax/copy/printer Machine With Toner software
Software
SOURCE: Canon FAXPHONE L80 confirmation
First print out your user data.
Press Function, then Report, then arrow down to User Data List and press Set. This gives you a printout of your present menu set.
Now press Function, press Data Registration, press Set. Arrow down to Report settings, press Set.
Select TX Report, select yes.
You can also select that the first page of the document sent shows up on the confirmation report.
Posted on Feb 23, 2008
  • 82 Answers
SOURCE: canon faxphone l75
what does it say on the display
Thank You,
Mikey
Posted on Apr 06, 2008
  • 64 Answers
SOURCE: Canon Fax L100 - toner required even though not empty
hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
Posted on May 21, 2008
SOURCE: Error message on Canon Fax Machine 2050P check cover/cart
there are a couple of things did you buy genuine or reman cartridges and check if they are seated properly.
some remans dont work properly so you have to be sure and always get a money back guarantee from the seller
Posted on Jun 08, 2008
  • 64 Answers
SOURCE: Check printer ##331 CANON FAXPHONE B95
HI your problem in fixing unit change it and your problem will be solved
Posted on Nov 08, 2008
If copy quality is very dark then what to do for making it normal
The dark quality is definitely linked to a light intensity problem. If the scanner lamp is operating properly then check for any reflective surfaces near the scanning lamp and clean those. It only takes a light film of dust to make copies dark. Be careful around the lamp, it is delicate.
Jan 26, 2015 | Canon 2234B007 - Faxphone, L90 Laser,...
My cannon faxphone L170 has dark lines that come through whenever we receive a fax.
Are the faxes from the same person or different people?
(I have to ask, remember I don't know how much knowledge you have.) If yes, it could be on their end.
Does it do this with copies also? If yes, May be dust on the mirror or
something in the printer getting in the way of the laser.{slight possibility].
How many prints are on the printer? Could be a fuser issue.
Jan 15, 2015 | Cannon Canon FAXPHONE L170 - multifunction...
I would like the software for Canon F152800 Faxphone. thank you!
Not sure what you are expecting... Are you hoping someone might drive it over to your place or maybe FedEx you a copy? Best answer is to search, find, download it on your pc
Jan 08, 2015 | Canon Office Equipment & Supplies
No print on rec'd or sent faxes
Surely you don't have blank copies rec'd and sent as these are two different parts of the machine entirely. I'll assume you mean rec'd and copied. Sounds like you've left a packaging seal on the cartridge to me - or it's a faulty cartridge. Remove the cartridge and check that all packaging has been removed - especially plastic strip that prevents toner from dropping into the cartridge.
Jul 01, 2009 | Canon FaxPhone L75 Plain Paper Laser
RECEIVED FAXES AND/OR COPIES PRINT ONLY HALF PAGE
Don't know that machine all that well, but it sounds like the laser filter glass may be dirty, or the laser unit. It seldom happens, but did you by any chance blow it out with compressed air?
Anyway, you may try taking out the toner cartridge, and if you tilt the machine upward you should see a sort of 'filter glass" above where the cartridge sits that allows the laser light to pass through from above. try cleaning this with a cloth, and hopefully that will solve your problem.
Mar 09, 2009 | Canon FAXPHONE L80 Laser
My Canon Faxphone L80 Ptints a solid black page when we receive a fax in-it's is sending a fax correctly.
Hello sir; Try to make a copy on this machine, if copy coming out good that's means the problem happen on remoted side.
Jan 14, 2009 | Canon FAXPHONE L80 Laser
Paper has dark marks down middle
If you make a copy, does the copy have dark areas down the middle of the page? If so, remove the toner cartridge and gently roll it around to redistribute the toner inside, maybe even replace the toner cartridge if you've had it a long while. If you still see unevenness, you may need to have the machine looked at.
If the copies you make on your machine look fine, then I would suspect that the person sending you the fax has a dirty scanning element. Check with them to see if they can clean the scanning element and it should improve the fax quality.
Oct 23, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Canon faxphone l75
Thank You,
Mikey
Mar 20, 2008 | Canon FaxPhone L75 Plain Paper Laser
Drum? glass? on faxphone?
try this take out drum( toner) clean machine see if there is a thin strip of glass on bottom inside the machine. make sure it is clean, this will give you black lines if dirty.
here is the manualit can guide you better, look for the troubleshooting and maintenance section
http://www.retrevo.com/s/canon+b640++manual?rt=tr&p=http%3A%2F%2Fwww.usa.canon.com%2Fcpr%2Fpdf%2FManuals%2Fb640_ug.pdf
good luck
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Canon F152800 Faxphone L90 Fax/copy/printer Machine With Toner Logo
346 people viewed this question
old marine
old marine
