Question about JVC MXKC68 Shelf System
MY JVC MX-KC68 wont play my cd's and reads no disc
It reads no disc when i try to play a cd?
  • 319 Answers
SOURCE: Error message No Disc
Unit has bad disk t-table motor
Posted on May 07, 2008
SOURCE: cd functon of JVC FS 7000
Clean the laser lens.
Posted on Jun 08, 2008
SOURCE: JVC Stereo won't open cd tray
take off the cover and get whatevers jamming it out mine did the same thing
Posted on Jul 30, 2008
  • 6771 Answers
SOURCE: my jvc 5 disc player
It is possible that the loading belt needs to be replaced, or the timing gears are out of sink, either way it must be taken apart to find the problem, sometimes I find the gears ware out causing the unit to lock up. When you hit the eject button do you hear a motor running? that should be the sound of the loading mechanism trying to eject the tray.
Posted on Dec 23, 2010
SOURCE: JVC MX-KC68. Works in stanby,
Surface Mount diodes around transformer on right back side of unit. Know issue with 38 and 68s.
http://www.forums.hcsd.com.au/cgi-bin/forum/Blah.pl?m-1301007851/
Posted on Aug 13, 2011
My jvc mx c33 will not play cd's that I burn, plays store bought ones fine. I am using Roxio NXT Pro to make my cd's on to a .cda format. The jvc mx c33 doesn't recognize the disk, just says there is
Are you closing the disc? If so are you using CRD or CRDW. If you are using CDRW it will not burn in the proper output format. If you use CDR only it should. Also try recording at a slower speed. It has helped me in the past to do so.
A great program to try is CDBurnerXP, and it's free. After you record it then put it back in and run it again, but this time just select "Disc" then from the drop down menu Disc Information [CTRL+I] and read what format you ended up with. Remove that and check a store bought disc and compare.
CDBurnerXP Free CD and DVD burning software
Dec 03, 2014 | JVC Audio Players & Recorders
JVC MX-D661T will not play discs 70% of the time
Yes it is the laser pickup assembly, you can try a cd cleaning kit and follow the instructions, if no change, far cheaper to replace the entire player.
May 25, 2012 | Technics SCEH790 CD Shelf System
Will not play any CD's and will only appear with the No Disc Error, I tried putting in a cleaning disc but it wont play either, help?
Maybe the laser gone out, try to see if it's the laser, if not, something in the cd motor or any other part might have stopped working
Aug 22, 2011 | JVC MX-K30 CD Shelf System
Hi , can you help me, my JVC car CD player doesn't play the cd ,it takes few seconds trying to read and then ejects the disc.
If this is only occuring when you try to play burned discs, try burning them at a slower rate (2x or 4x)
If this is occuring with storebought discs, You'll need to clean your laser lens. Cleaner Cd's are available from pretty much everywhere that sells Discs.
May 11, 2011 | JVC Audio Players & Recorders
May 06, 2008 | JVC MX-J200 CD Shelf System
Wont read audio discs
If you used a cleaning disc, try again only this time open up the unit and clean the lens using a cotton swab and alcohol. Those cleaning discs rarely work. Let me know if yuo still have a problem.
Dan
May 01, 2008 | JVC MX-K30 CD Shelf System
Cd player won't play discs
Maybe you should try cleaning the lens by opening the shelf TOP, and cleaning the lens? I had that problem. Take a Q - Tip with alcohol on it and it will do the job. Careful to not touch any components, and unplug first! The system can electrocute you even if unplugged, so don't touch any electronic component else than the lens inside.
Nov 28, 2007 | JVC MX-K30 CD Shelf System
CDs won't play
Maybe you should fix the cds or clean them or try to fix the disc reader in the radio.
Nov 09, 2007 | JVC MX-KB30 CD Shelf System
JVC MX-KB30
Have it first cleaned by a cd disc cleaner or if you are familiar with cleaning the lens manually im sure that will work...or try inserting an original cd's,if it works with that find the solution to the settings of your device...
Sep 22, 2007 | JVC MX-KB30 CD Shelf System
JVC MXKC68 Shelf System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
