Question about Drills
I need the belt sizes for a Guardian Power Model FDM-58-12S Drill Press.
SOURCE: replace belt
Sourced the part no and stock number on the Draper site, then sourced the Manual on the Draper site too
Posted on Nov 18, 2009
  • 760 Answers
SOURCE: I have a Guardian Power floor model drill press.
Can you move the spindle up and down with the handle? If you can't make sure the spindle lock is not on. Is the spindle clean and rust free , well lubed? Here is a link to a manual for your drill press: http://www.dewaltservicenet.com/Products/ProductManual.aspx?q=15-331 You can order parts here. Usually the return spring can be adjusted with a nut on the left side of press. Possilby the return spring could be broken.
Posted on Jul 12, 2010
puertobori
  • 7733 Answers
SOURCE: I have a Guardian bench mount drill press Model #
Look at eReplacementParts.com and the parts diagrams
Posted on Nov 02, 2010
SOURCE: Bought a craftsman drill press mod. 11321370 and
try managemylife.com
Posted on Dec 27, 2010
  • 11 Answers
SOURCE: I have an old Guardian
sounds like either the pulley is not tight to the spindle or the spindle is broken in half either in a bearing race or between the two spindle bearings
Posted on Mar 18, 2011
Guardian Power Drill Press BDM-58-12S Manual
Try Googling (Guardian)(BDM-58-12S)(manual) without parens.
Apr 05, 2018 | Drills
How do you move the belts on guardian power 16-speed drill press?
They just slip off to move, the motor is spring loaded.
Mar 09, 2018 | Drills
How do I make the spindle chuck stay in the quill of my model FDM 16 SPC drill press? I have forced it down on a block of wood. It will stay for a while that fall out.
16 speed should have a Morse taper
for the std drill chuck
to fit a different chuck the morse taper needs to be emery sanded
and the replacement chuck should stick
after using the wood block pressure press method
if not you need a new morse taper for that spindle chuck
hint
i had my drill accuracy and off center spin tolerance down to one thou
with stretched old belts I got more speeds than 16
for special jobs
my 16 speed used a morse taper two for the drill chuck
this picture says its a spindle chuck
26313356-3kt1rk2qq1yye1uaamrjudob-5-0.jpg morse taper
Oct 16, 2016 | Drills
I need the owners manual for Guardian Power drill press Model# FDM-58-16S
Hello, Call Guardian at 1-877-934-3585. For help with obtaining a manual.
May 15, 2014 | Drills
I have a guardian power floor model drill press model FDM 58 12SP where can I find a 5/8 chuck
in perth i would try ron mac machinery sales.. in other states also machinery sales for trades or companies in steel work.. pete
May 11, 2014 | Drills
I have an old Guardian Power drill press and I broke the handle. Does anyone know where I can find parts for it? Model #BDM58-5S
Jet JDP 12 Parts List and Diagram 707300 eReplacementParts com
This site has parts for several brands of drill presses, so you may be able to match up the part that you need. The page I tagged is for reference . You'll have to search the site for a part that possibly works for you. Hope this helpful. There are other sites that have parts, but I did not find the Guardian.
Dec 01, 2013 | Drills
How do you get a morse taper chuck out of a guardian power 12 sp drill press
Everywhere there is the same kind of remove or by a long axle insite the top pulley down
How To Remove Morse Taper Mounted Chuck From Drill Press AutoDrill
Mar 17, 2013 | Delta 15 331 15" 115/230V Variable Speed...
I have an old Guardian Power floor model drill press and do not know how to change belt positions to change speed. help please.
See the picture below. The small red circle shows the locking screw on the right side of the drill. There is another locking screw on the left side of the drill. Loosen them both a half turn. The larger red oval is the handle to pull the motor closer to the spindle, thereby loosening the belt. Once loosened, it is easy to move the belt. Then use the handle to push the motor back, which tightens the belt. Keep pushing on that handle with your right hand while you tighten the locking screw on the left side of the drill with your left hand. Once you have that tight then tighten the right side locking screw.
Good luck! I hope this helps.
Jul 12, 2012 | Drills
I need the owners manual for a Guardian Power drill press Model# FDM-58-16S........Help...................
I'm looking for a Owner's Manual for a 16 speed, 1/2 hp, Heavy duty Guardian Power drill press.
Apr 17, 2010 | Drills
Drills Logo
189 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
