Question about Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do I set correct day of the week
2556
  • Casio Master
  • 18,392 Answers
How to set day/date on an 1968 DX automatic Seiko watch
Seiko watches from this period should have a setting stem that pull out half-way and fully. Pulling the stem out fully permits you to set the time. Pulling the stem out half-way should let you set the date by moving the crown forward/clockwise and set the day of the week by moving the crown backward/counterclockwise.
However, for this to work correctly, the watch must have the correct set stem. I have worked with a number of watches, including Seikos, where a generic stem was substituted after someone accidentally pulled out the crown and stem (Seiko replacement parts can be tough to find in the U.S., especially for discontinued models). If an incorrect stem has been installed, the day/date setting procedure I've just described may no longer work correctly. At that point, setting the date involves advancing the hands to get to the right date; day of the week may not be able to be set at all.
Mar 09, 2012 | Watches
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
I can't set the day of week on my Casio, CA-53W. Thanks
If the day of the week is incorrect, make sure the date is set correctly. The format on the Casio CA-53W is year first, then month, then day last.
May 31, 2011 | Casio New CASIO CA-53W Water Resistant...
I purchased a Marco Max watch with day, date and moon phase. How do I set each of the dials to match the correct day of week, month and hour?
The crown has three positions. The A position is when it’s pushed all the way in. You can’t set anything in this position. The C position is when it’s pulled all the way out. The B position is the click between all the way in and all the way out. My biggest problem is that I read the directions to mean that there were FOUR positions. I didn’t realize A was all the way in. I thought there was three pulled out positions.
To set the day of the week (Sun, Mon, etc.): Pull the crown all the way out (position C) and turn the time to just after midnight. The setting will click to the next day. To advance it an additional day, you don’t have to turn the hands another twenty four hours. You can turn the hands backward to before midnight (you will see the day of the week setting click a little, but not go backwards), then turn the hands past midnight again.
I recommend setting the day of the week setting to YESTERDAY. You’ll see why later.
To set the date: 3341598183_60e77d12e5.jpgPull the crown one click out (position B) and turn the crown away from you (clockwise). This will advance the day indicator (it looks like a second hand). To set the month, you have to keep turning until you get past an entire year. There is no separate way to set the month. To make the correct month show, you must keep turning the crown past every day of the year until you get to the correct day.
I recommend setting the date to YESTERDAY. I’ll explain why later.
To set the moon phase: Pull the crown one click out (position B) and turn the crown toward you (counter clockwise). To find out what phase the moon is currently in, here are a couple of websites:
Once again, set it to the moon phase for YESTERDAY.
To set the time: Pull the crown all the way out (position C) and turn the crown either away or towards you to set the time. Keep turning the time away from you (clockwise) until you get past midnight. Once you get past midnight, ALL the settings should change (day of the week, date and moon phase). Now you KNOW you’re on today’s date at just after midnight. Set the correct time and your Luar watch is ready to go!
Review 3342440924_5fa48ca4fe.jpgMany of the Swatch enthusiasts were disappointed that the Luar is a battery powered watch instead of an automatic. With a price tag of approximately $450, it’s a little much to expect an automatic with a real moon phase. I’ve talked at length about what I desire in a watch here:
My desires have changed a lot since that day nearly four years ago when I went looking for the perfect
To set the date: Pull the crown one click out (position B) and turn the crown away from you (clockwise). This will advance the day indicator (it looks like a second hand). To set the month, you have to keep turning until you get past an entire year. There is no separate way to set the month. To make the correct month show, you must keep turning the crown past every day of the year until you get to the correct day.
To set the time: Pull the crown all the way out (position C) and turn the crown either away or towards you to set the time. Keep turning the time away from you (clockwise) until you get past midnight. Once you get past midnight, ALL the settings should change (day of the week, date and moon phase). Now you KNOW you’re on today’s date at just after midnight. Set the correct time and your watch is ready to go!
Aug 11, 2010 | Watches
I want a new strap for Diesel dz4083 from were i can get.
If you need help with product information, ordering assistance, or returns information you can contact us via one of these three options:
Diesel Time Frames Customer Service
2280 N. Greenville Ave.
Richardson, TX 75082
TEL: 800-699-2556
customerservice@dieseltimeframes.com
Alternatively, touch your toes together 3-times and repeat softly: "There's no watch like Diesel Time Frames, There's no watch like Diesel Time Frames, there's no watch like Diesel Time Frames" and you will be transported to our customer service center in Kansas. Or maybe Texas. Or maybe not. If this fails, try one of the other 3 methods of contacting us listed below.
You've got a choice. You can contact us by telephone at 800-699-2556 between the hours of 8:00am - 6:00pm CST, Monday through Friday. Or you can email us at customerservice@dieseltimeframes.com. We aim to respond to your email within 24 hours, excluding weekends, or during the office fishing trip the third week of June.
Jul 23, 2010 | Diesel DZ4083 Watch for Men
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 | Watches
How do i set the day of the week on my Invicta subaqua noma 6125?
For Invicta chronographs to set the day you need to pull the crown out to position 3 (2nd click after releasing the crown/ furthest crown position/ same position to adjust time). You can only set the day by rotating the crown clockwise. Every 24 hours of clockwise rotation will move the day indicator forward 1 position (Mon>Tue, Tue>Wed, etc). If your watch is set one day ahead of the correct day (Its Tuesday but the watch displays Wednesday for example) you will need to rotate the crown clockwise through the entire remainder of the week in order to get to the correct day, you CANNOT rotate the crown counter-clockwise in order to move the indicator back a day.
May 21, 2010 | Invicta Subaqua Noma Iii Chronograph men...
Setting time, date, month and day for diesel model dz7087
As there is no possibilities to download manual for your watch, you have to contact Diesel yourself by email or by phone. Here is the contact info:
TEL: 800-699-2556
Don't forget to rate, please.
Jan 14, 2009 | Bulova Watch
Setting day and date on timex watch
Pull the stem out part of the way not all of the way. This will allow you to change the date quickly without the day moving.
Nov 26, 2008 | Timex 27191 Wristwatch
Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
87 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
