Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a 15 HP. Sears Lawn Tractor with a Koehler Engine.
The starter doesn't want to engage sometimes when I try to start it. I keep turning on the switch and it clicks and that is it. After a while it will finally engage and start. I changed the solenoid and that didn't seem to help. Before I spend 100$ plus for a new starter is there something else I should do?
  • healthex Feb 11, 2009
    What is the st side of starter?
  • 398 Answers
SOURCE: MY MOWER WANT START
probably a bad starter hit it on on end with something a hammer or rod a few time and try to start it right away. if that works its a bad starter needs replacing
Posted on Feb 26, 2009
GM Elec
  • 1000 Answers
SOURCE: difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Posted on Aug 21, 2009
agent91
  • 2100 Answers
SOURCE: Tractor clicks when key is turned, but doesn't always start.
If you have a new battery and it clicks, it is not a safety switch, but we won't rule out the solenoid yet, I would say dirt, check the battery terminal for dirt, clean them up with a wire brush, Make sure the battery is good, test it for voltage and specific gravity, one of those floaty ball things. Try it, if it still clicks, get the hammer, tap on one of the bolts holding the starter, just lightly to loosen the solenoid, if it jumps to life, you have found your problem, if not, Hit it harder, no, It doesn't have to be hit hard at all, just a tap will do it. My John Deere tractor has a hammer on the running board, the only way I can start it. The bolt head is rounded right off. Been like that for 15 years. Hope this helps.
Posted on May 07, 2010
  • 640 Answers
SOURCE: my name is jim. My Sears Craftsman lawn Tractor
Clean the carburetor. The needle and float are stuck closed, passage blocked or a jet plugged with debris. Give it a good cleaning.
Posted on Jul 31, 2011
SOURCE: Craftsman Lawn Tractor, 18 HP, 44" Cut; No SWtart!
Check the by pass switches on the seat, clutch pedal, and check the fuses.
Posted on May 27, 2012
Sears Garden tractor does not start, how to i test to see if it is the starter or solenoid or what?
Try turning it over with the spark plug removed. If it now turns over the starter is weak and needs to be replaced. Also check the oil level. Too much oil will will lock it up.
Apr 14, 2013 | Craftsman Lawn Tractor Operators Manual...
Starter won't engage on 17.5 koehler command
Try replacing the solenoid. If that doesn't do it, replace the starter.
May 05, 2012 | John Deere Garden
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I HAVE A CUB CADET LT1050 LAWN TRACTOR AND WHEN I TURN THE KEY I GET ONE SINGLE CLICK. THE STARTER DOESN'T ENGAGE
Hi camy wils815...
Sounds like you have a faulty solinoid.
Make sure your battery has a full charge, the by-pass the starter solinoid on the engine.
To do this ground one big wire connection to one of the small wire connectors (with the wires still hooked up) and if it starts, then replace the solinoid...if it does nothing, replace the solinoid.
Please take time to rate me
Jul 30, 2011 | Cub Cadet Street Sign- tractor lawn riding...
My name is jim. My Sears Craftsman lawn Tractor
Jul 30, 2011 | Craftsman Garden
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My craftsman lt 1000 lawn tractor will not start. When I turn the key the starter motor spins but the gear will not raise up and engage the flywheel. Do I need a new starter? (18 hp b&s 42 Inch cut) If...
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
  3. Engine stalls immediately when started
    1. Check the ignition switch condition and operation. The electrical contacts in the run position may be worn or damaged. Try restarting the engine with all electrical accessories in the off position. Sometimes turning the key on an off will help in emergency situations, however once the switch has shown signs of failure, it should be replaced as soon as possible.
    2. Check for loose, corroded, damaged or shorted wires for the ignition system and repair or replace.
    3. Check for manifold vacuum leaks or vacuum hose leakage and repair or replace parts as necessary.
    4. Measure the fuel pump delivery volume and pressure. Low fuel pump pressure can also be noticed as a lack of power when accelerating. Make sure the fuel pump lines are not restricted. The fuel pump output is not adjustable and requires fuel pump replacement to repair.
    5. Check the engine fuel and ignition management system. Inspect the sensor wiring and electrical connectors. A dirty, loose or damaged sensor or control module wire can simulate a failed component.
    6. Check the exhaust system for internal restrictions.
May 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Tractor won't start
try replacing the relay in the middle of the ignition and starter.
Apr 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MY MOWER WANT START
Feb 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Tractor Battery
Mabye it was a bad battery of it could have to do with the sparkplug being flooded.
Nov 04, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
210 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
