Question about Ovens
Ecofit 2gdsu35 133x126r single inlet centrifugal fan has failed. can u replace , or repair?
Oven fan not working
Check the clock is in manual mode. If it is and the fan is still not operating but you can see the element glowing behind the back panel, the fan has probably failed and needs replacing
Mar 22, 2013 | Neff B1428 Nostalgic Single circotherm...
Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Apr 03, 2010 | Belling XOU174 Electric Single Oven
Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
Indesit FIE 56 K.B GB oven The circulation fan is squeeking
The symptons you describe are typical of the fan motor bearings failing. you could try spraying the bearings with WD40, but this would only be a temporary solution, in the end you will probably have to replace the fan motor complete.
Hope this helps.
Jan 07, 2010 | KitchenAid KEBC101 Electric Single Oven
The fan on my circotherm double oven does not come on straight away any more
Assuming the fan does start eventually, then I would say that the fan bearings are starting to fail.
You could try spraying the bearings with WD40,, but long term, you are probably going to have to replace the fan motor.
Hope this helps with your prob.
Nov 28, 2009 | Neff B1432 Single circotherm plus Electric...
Candy oven noisy fan
Noisy fan means bushes are worn. cant be repaired. needs replacement. Quote model of oven to spare parts supplier and replace. Make sure power is unplugged and not just switched off before repairs are done.
Sep 14, 2009 | Candy FP855 Electric Single Oven
Candy F254/3X single fan oven, grill works, oven doesn't.
If fan is working o/k, then you need to fit a new oven element
Please`rate my solution.
Thanks.
Aug 24, 2009 | Candy F248P Electric Single Oven
STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Apr 22, 2009 | Stoves Premier 600EMa Electric Single Oven
AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Aug 24, 2008 | AEG B2100-4 Electric Single Oven
Neff b1421 single oven
I suspect that the thermostat has failed
Aug 07, 2008 | Neff B1421 Electric Single Oven
Ovens Logo
50 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
