Question about Brookstone HDMI Pocket Projector
Iphone 5 and brookstone hdmi projector connections
How do I get a replace ment battery for , my brookstone hdmi projector
Try eBay, we do not sell parts here or have any locator services.
May 01, 2018 | Cars & Trucks
Projector turns on, displays Brookstone logo and then turns off. It's not the power; the unit is plugged in.
It is most likely your lamp. If you replace the lamp then you need to reset the lamp timer back to zero or it will keep shutting off on you.
Jan 15, 2016 | Brookstone AAXA 50 Lumen HDMI 720p P3 Pico...
There is a blue line when plugged into laptop
I had the same problem. The projector works wonderfully connected to my iPhone (with an adapter), and connected to other kinds of laptops, but not with mine. Apparently the projector is not compatible with every laptop. I had to connect my projector to my laptop via a Netgear PTV1000 streaming player in order to use it.
You connect to the player wirelessly. Then use the HDMI cable to connect the player to the projector.
Streaming Players
I happened to already have the player so I didn't have to purchase a new device. I hope this helps you.
Jun 28, 2014 | Brookstone HDMI Pocket Projector
BROOKSTONE HDMI PROJECTOR 801143 DOES NOT CHARGE
The Brookstone manual claims it will fully charge after 3-5 hours, but it takes much longer then that. Mine does not indicate green light, but it seems it stops blinking red when its fully charged. After that it run on power directly from the ac-adapter.
If you keep it connected to the AC-adapter after it have stopped blinking red (do not disconnect it at all), it will start to run on the adapter and will not turn off. You will feel the AC-adapter gets hot while its running, something it does not while regular charging.
If it still dont stop blinking red after having it connected to power for 3 days, your AC-adapter is probably faulty. This happened to me, and after allot of research I found this replacement from a US seller on ebay (only five dollars included shipping).
http://www.ebay.com/itm/251623019268?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Good luck with your projector. It a really cool little thing, but it has some design flaws.
Best regards.
Feb 17, 2014 | Brookstone HDMI Pocket Projector
Brookstone pocket projector wont turn off
i'm having the same issue. it 1st started with a No Signal error. then this started...ugh!
Feb 10, 2014 | Brookstone Pocket Projector for iPhone 4...
New iphone 5 does not fit on the base
They do make an adapter that you can purchase from the Apple store. This was a common issue when Apple switched from the 30 pin connectors to the new lightning ports which are much smaller.
http://store.apple.com/us/product/MD823ZM/A/lightning-to-30-pin-adapter
Hope that helps!
Dec 04, 2013 | Brookstone Idesign Wafer Cd System For...
Hooked hdmi dongle to projector. Used kindle fire hdx. Picture works fine but no sound from projector speakers. No sound from kindle speakers. Need to use kindle headphone jack for sound.
follow this steps and fix it. God bless you
Check the system requirements on the Bluetooth dongle. If your system does not fit all the requirements, the device is not going to work. The requirements for the Bluetooth dongle are printed in the user manual and packaging. You may compare this to what is running on the computer by clicking "Start," "Control Panel" and "System." This displays the hardware running on the computer.
    • 2
Disconnect the Bluetooth dongle, restart the computer, then plug it back into a USB port. If you power on the computer with the dongle already instead, the system may not detect the equipment. Restarting the computer and performing this action helps correct the problem.
    • 3
Remove the Bluetooth dongle from the USB port and plug it into a different connection. Some USB ports fail to detect certain computer hardware. Changing the connection port fixes this.
    • 4
Install the driver on the provided driver installation CD. Without the driver, the computer is unable to detect and use the dongle. Insert the driver installation CD into the disc drive of the computer, then follow the on-screen steps to install the driver onto the system.
Oct 29, 2013 | Brookstone HDMI Pocket Projector
Hdmi pocket projector color off blue displayed as red
I bought 1 today. This evening I tried it with my camera Sony HDR250V And I noted It has the same problem You Have. How did You solve it?
Jun 21, 2013 | Brookstone HDMI Pocket Projector
Brookstone HDMI Pocket Projector Logo
Top Brookstone Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
