Question about Drills
Alternative chuck key specifications
Trying to find pilot size on Delta drill press chuck, part #1310049. Lost chuck key to delta drill press 11-950
rowdy45176
  • 2176 Answers
SOURCE: The shaft on my Delta floor mdoel press drill keeps sliding out
This sounds like a morse taper adaptor. if so look at the taper for any unusual wear. if none what I would do is get something like brake clean or similar product to remove all oil and grease. clean the shaft and the internal socket. wipe off with cleam paper towel after cleaning. retract the chuck jaws to prevent damage to the chuck and align the tang on adaptor with the internal socket. Take a piece of wood and hammer and hit the chuck seating the taper. You can also try using the table with a block of wood and the feed handle to seat it. If it continues to fall you have worn parts that need replaced. Good luck
Posted on Jan 07, 2009
  • 205 Answers
SOURCE: delta 8' table top drill press
If the spindle is tapered, and you have a tapered chuck, it is a interference fit. You can move the table out of the way for swinging room and smack it on with a mallet. Or you can block the chuck up on the table and force the spindle into it.
Both spindle should be smooth and clean, sometimes if a drill bit grabs and stops it will twist the chuck off and gall up the taper surfaces. Put some chalk dust on the spindle before assembling if you have some, it will help prevent galling should the chuck come off
Posted on Mar 29, 2009
  • 10865 Answers
SOURCE: the chuck has come off my delta desktop drill
clean the spindle and the inside of the chuck with easy off oven cleaner. get it all very clean and then be sure to remove all of the debris. pound the chuck onto the spindle with either a rubber mallet or put a block of wood under the chuck and use a regular hammer. DO NOT hit the chuck directly with a steel hammer.
Posted on May 10, 2009
efs_perpends
  • 1996 Answers
SOURCE: I need a manual.
Unfortunately, an online manual for that model isn't available online from the delta site, but if you go here you'll at least be able to access an exploded parts diagram and list. Perhaps that will help.
If you really need a manual, take a look at this list and maybe there's something there you can use.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 22, 2009
deme-tri
  • 90 Answers
SOURCE: How to change belt
THERE IS A LITTLE HANDLE AT THE SIDE
PUSH IT UP THEN TAKE OUT THE OLD ONE
AND REPLACED
Posted on Aug 04, 2009
What size taper is on a delta DP220 drill press so I CAN BUY A 1/2" DRILL CHUCK TO PUT ON IT
If its possible, pop along to a local machine shop and ask nicely if they could help with identifying the Morse Taper, if its a Morse. Go online for what tapers would have been used around that period. Drill chucks are usually 1/2 UNF mount even if its a late metric unit. You would need a Morse to 1/2 UNF or taper to taper if you buy a taper fit chuck.
Dec 29, 2014 | Delta Woodworking Vintage Delta Dp 220 14"...
How do you remove the drill chuck on a vintage delta 14 inch drill press model dp-220
Thread Changing chuck on older Delta drill press This site speaks on the subject of changing chucks. It may be helpful. Also if you search;' how to remove a jacobs chuck from a delta drill press' , you should get several hits I hope this info is helpful....
Oct 17, 2013 | Delta Woodworking Drills
Where can I find a replacement chuck key for a Delta 11-950 bench press?
No you don't have to buy Delta's chuck key. MOST drill press chuck keys are very similar but if you do order another companies key and it doesn't fit, you may be stuck with it. If you have a local tool repair center that carries keys you can try one and if it don't work, return it.
The Delta part number for your chuck key is 1313104. It is avaliable from Dewalt (they own Delta) on their service website at http://servicenet.dewalt.com. You can also get it at aftermarket sites like www.ereplacementparts.com for only $11 plus shipping.
Sep 15, 2012 | Delta Machinery Drills
I just bought a used DP200 Delta drill press. The chuck seems to be locked up in the closed position. I want to try to open and insert a bit, but am afraid of breaking something.
If it's locked up that tight the only thing you can do is turn the key as hard as you can until it either breaks free and works or just plain breaks. If it breaks free, spray a bunch of WD40 or like lubricant up into it, cycle the chuck to full open and full closed a few times to let it soak in then blow it out. If it's working freely throughout the travel and not sticking it should be OK. If it broke while trying to open, sticks while cycling it or just plain won't open, replace it. You need part number 1310049 from Delta to replace it (shop the internet for one). The chuck is just pressed on to the tapered spindle so you have to extend the spindle all the way down and hit the top of chuck, sometimes hard depending on how long it's been on there.
Dec 24, 2011 | Delta Dp115 Dp200 Dp300 Drill Press Sleeve...
How do you remove the chuck from a Delta shopmaster 350 bench top drill press?
there is a "drift pin" that came with the tool, you would need to insert it into the slot and tap on it.
Sep 08, 2011 | Delta DP350 Shopmaster 1/3 Horsepower 12...
I have an old Delta D-220 drill press. While the chuck spins true, even at high speed, a drill bit will have a slight wobble towards the end of the bit. I tried many bits so its not a bent bit. Solutions? ...
You are right,but if the wobble is not too big to do drill jobs it can be used.Sometimes drill jobs need to be precise,so the you will need it just aligned.
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or go direct to this link.
Good price and service.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | Delta Woodworking Vintage Delta Dp 220 14"...
Where can I buy a new chuck for my 15-091 dp?
You cn find MANY chucks on eBay. You need to verify the size and the mounting which is LIKELY a Morse taper. ONLY buy new ones. There are some for as low as $8.
Prefered brand is "Jacob's".
Jul 16, 2010 | Delta rockwell 15" Vs6 Drill Press...
The chuck has come off my delta desktop drill press. nothing i can do will get it to stay on.
Mar 31, 2009 | Delta 15IN Stroke Production Drill Press /...
Jan 06, 2009 | Delta 15IN Stroke Production Drill Press /...
Drills Logo
35 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
