Question about GE 106591 Coffee Maker
Part Are any replacement parts available? Specifically, I need that small, round clear plastic lid that fits over the grinder.
    President:
  • 1,214 Answers
Go to the GE website and look for parts for that nit. You may also try SearsPartsDirect.com.
Posted on Jan 25, 2009
I was trying to clean my coffee grinder and when I took the bottom off a clear plastic came out and I can't get it back in.
see the steps:God bless you
  • Unplug the coffee grinder and wipe out as much residue as possible with a paper towel or clean cloth.
  • 2 Plug in the grinder. Add a little dry, uncooked rice to the grinder and turn on the grinder. Grind the rice until the grinder no longer has an odor or until the rice is finely ground. Repeat this step if necessary.
  • 3 Unplug the grinder and remove the ground rice completely. Wipe again with a paper towel or clean cloth.
  • 4 Hand wash any removable lid to the coffee grinder with dishwashing liquid. Allow to air dry.
  • 5 Clean the exterior of the coffee grinder with a damp cloth or paper towel
    however download your instr.manual www.fitness.manualsonline.com
  • Sep 24, 2012 | Coffee Makers & Espresso Machines
    Tip
    Krups 203 Blade Replacement Procedure
    <span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
    on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
    I need a new lid for my Russell Hobbs 9702 Coffee Grinder but the item is no longer available and I can't find spares. The little plastic tab on the lid has broken off, this tab makes the grinder work...
    fold a piece of paper or thin card board and put it in the hole the tab went in and you can have your coffee until you can find a replacement on ebay or amazon.
    May 20, 2011 | Russell Hobbs Microwave Ovens
    The plastic top of the glass pot on two coffee makers drip.
    This is a design flaw and can be corrected by enlarging the lid spout. First remove the plastic lid. Then use a fine grinder or sandpaper to remove approximately 1/8 inch of plastic from the lid spout. Follow the exact same contour of the oval spout. However, do not take off so much material that you disturb the small plastic tabs that hold the lid to the pot. Finish by slightly rounding the edges where the material was removed with fine sandpaper. No leaks - no drips.
    Apr 26, 2009 | Cuisinart DCC-1200 Coffee Maker
    Embarassing but...
    No, wait, I found it. If it's round and is (or used to be) white, it fits on the bottom of the clear plastic hopper. Replace it and you should be in good shape again.
    Jan 02, 2009 | Solis Maestro Electric Burr Grinder
    G E /Walmart Coffee maker/ Grinder Model # 169082
    The grinder parts have to be in place and the lid closed or it will not work. The plastic cover to the grinder twists to the left which engages a small switch. Hope this helps!
    Aug 05, 2008 | Coffee Makers & Espresso Machines
    Burr grinder GVX212
    I had the same problem, took it all apart, separated the two halves, and looked into the guts of the machine, not an easy task. Fiddled with this and that, and looked at the back of the switch mechanism, and heard it making a 'click' when depressed, so put it all back together, to no avail...It turns out the grinder needs to have two limit switches engaged, one between the lid of the ground coffee hopper and the underside of the grinder hopper housing, and the other between the grinder lid and the base of the unit. This last limit switch was my problem, it seems the lid wasn't making contact with the limit switch, so the unit didn't run. I cleaned out the narrow gap that the grinder lid sits within, pressed the lid down until I heard a small 'click' , pressed the on switch, and presto! it works. You can see this very tiny switch if you take off the grinder lid, and look in the narrow gap it sits in at a position of about three o'clock ( the back of the machine when viewed from the top being 12 o'clock. Hope this helps anyone else who can't find their receipt within the one year warranty period. This is the best burr grinder I've found for the money, and I'm glad mine's still o.k.
    May 20, 2008 | Krups Burr Coffee Grinder
    GE 106591 Coffee Maker Logo
    55 people viewed this question
    Top GE Coffee Makers & Espresso Machines Experts
    Joseph Hoffmann
    Eric Taylor
    Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
