How to connect huawei ws320 to livebox 7958
Can not connect to my livebox 7958
No Internet connexion between livebox 2zte and dap 1320 .
First connect to the Livebox (without the range extender) to see if you can access the internet. If you can get on the net there open your browser and type http://dlinkap.local in the address line, and set-up the d-link. the most common problem is the password on the router (the livebox).
For instructions for the D-Link go here;
http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201320/Manual/DAP_1320_Manual_EU.pdf
For instructions for the livebox (translated into english);
http://translate.google.com/translate?hl=en&sl=fr&u=http://assistance.orange.fr/installer-la-livebox-2-zte-4665.php&prev=/search%3Fq%3Dlivebox%2B2zte%26rlz%3D1C1ASUT_enUS567US567%26es_sm%3D93
May 18, 2014 | Office Equipment & Supplies
I am in france trying to connect my macbookair to a french livebox
Yes, you need to press button #1 on the livebox , which will put it into 'accepting new wifi devices' mode. This lasts about 1 hour.Presumably you've entered the wep key from the label on the bottom of the livebox into your macbook? don't forget it's got to be UPPERCASE characters!
Apr 27, 2012 | Apple Computers & Internet
Canot connect Ipad 2 to orange livebox.
You must connect via wifi to your livebox without problems. You may only go to Ipad settings and select the livebox wifi. I do not understand the problem.
Sep 16, 2011 | Apple iPad 32 GB WiFi Tablet PC
Is it compatible with livebox2 it does not respond with livebox2
Yes it is compatible with any livebox as long you have a wifi connection...You just nees to reset your phone and security key and reset your livebox and type in the security key of your livebox its always found under the livebox.
Apr 22, 2011 | Samsung Lands Phones
Wireless connection using livebox and belkin usb adaptor
You most likely need to reconfigure the livebox settings. The Livebox lost the settings because it was unplugged too long. Most router settings can be accessed by typing in 192.168.1.1 or 192.168.0.1 in the URL address bar of any web browser. From there, make sure that all other switches and devices on the network are on the same network. Meaning if your Livebox default gateway is 192.168.1.1 make that the switch that other devices are connecting to the network through are assigned the IP address 192.168.1.x where x is any number other than 1. I hope this help, I know its not comprehensive enough but once I'm a 'Guide' you will be able to chat with. Then we can have conversation via IM Chat. This is my area of expertise.
Jun 17, 2009 | IBM (34L1209) Network Adapter
I cant get my I Pod Touch to connect to my Livebox. I have put in every password I can think of including the 26 digit Livebox one - any ideas. It is so frustrating to have been given my I Pod as a...
You need to out the Livebox into pairing mode to allow the iPod Touch to connect.
Press the button marked '1' on the back of the Livebox. This will start the wireless LED flashing and puts the Livebox into 'Pairing' mode.
Use the WEP key that is printed on the label on the bottom of the Livebox.
NOTE: There is a limit to the number of devices you can connect.(6)
Apr 13, 2009 | Apple Computers & Internet
X box 360 wont connect to orange livebox!!!
there could be a problem with the xbox wireless adpter which it maybe a fautly item
Feb 18, 2009 | Microsoft Xbox 360 Console
Livebox wired connection
Well if the modem isnt working have the isp come out and replace it.
Apr 29, 2008 | Computers & Internet
Connecting ipod touch
Press pairing 1 button on the back of the livebox and then type in security code make sure that you type in each character in capital letters as the code it is case sensitive (don't set caps lock) for each character use the shift key - You will now be connected to the livebox.
Jan 15, 2008 | Audio Players & Recorders
Orange Livebox and NIC
Sounds like an internal problem with the Orange Livebox NIC controller.
If you have an other router Lynksys/belkin you could try it would isolate the problem definitively
Nov 26, 2007 | Powerline Ethernet Network Adapter
Computers & Internet Logo
David Payne
David Payne
