Question about Fujitsu fi-6230 Flatbed Scanner
Problem installing driver for Fi-6230 on Windows 7 system
Upgraded system from Windows XP to Windows 7. Use to have a fi-4220c scanner and now have a fi-6230. When I try to install the driver for the fi-6230 it gives me a error message " Please remove scanner utility for microsoft windows" I went into ADD/Remove programs and tryed to uninstall it, but it will not uninstall. This is not allowing me to install the driver for the new scanner. Can you help?
5 Suggested Answers
PcExpert
  • 293 Answers
SOURCE: Windows can't find driver for FI-5660C
THE PROPER WAY ON INSTALLING USB DEVICES 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Posted on Sep 19, 2007
  • 15 Answers
SOURCE: fi=5120c conflict with another scanner
Check in the order as i had written.
1. Is both the scanners are connected in usb, then this problem will arise. Connect fujistu in scsi and check it. And connect only the cannon and check. because there is a chance of usb port or usb cable problem.
2. Then it depends up on the driver you are selecting. whether you may be selecting fujitsu and giving scan .
3. Check is the driver for cannon is properly installed and also have a check in the device manager is there is any question mark is showing in the driver for particular scanner.
4. If you are using any certain application like scandall application you can select the scanner whichyou want it to scan by selecting the SELECT SCANNER.
5. Is your driver is a new version. If new version is available then update the driver and check it out.
If you have any other problem you can contact me .Regd. the fujistu i can help you.
My mail id is : ramanathanr@integramicro.com.
Posted on Nov 11, 2008
SOURCE: looking for a win 7 driver for a Fujitsu fi-4220c
pls give me the software & dirver for scaner fi4220c2.merci!
Posted on Feb 28, 2011
TechSatya
  • 104 Answers
SOURCE: Hi, I want to install both
There is no need of installing driver for fi-5530c2 scanner as the driver comes bendled in the fi-5750c scanner. Hence, please install the driver for fi-5750c.On the application, you need to chnage the scanner model under "Select Scanner" menu.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Posted on Dec 13, 2011
I need the software to fujitsu fi-4120c2 - I have windows 7
Hi kimberly...
fujitsu fi-4120C2 printer drivers can be found at driverupdate us (xp/vista/7/8).
It will take 2 mins from you to install...
after updating, go to word and try to print something
I hope I have helped you...
enjoy
Apr 06, 2012 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Does fi 5120 driver works on Window 7?
Fujitsu fi-5120C is compatible with Windows 7. However, you have to download and install the scanner drivers for Windows 7. Click HERE to download the required drivers and toolkit (Installation & User Guides are also available).
Run the downloaded file and follow the on-screen instructions to install the scanner drivers/ toolkit.
Hope it helps! Good Luck!
CreativeTECH
Mar 16, 2011 | Fujitsu fi-5120C
I was just upgraded to Windows 7 and after using it for about 3 days, now my scanner is not being recognized by the system. How do I reload it to recognize on my computer without any disks?
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/
kindly update the fujitsu scanner driver for your 5110 scanner to windows 7..
Mar 14, 2011 | Fujitsu fi-5110C ScanMaker Scanner
Where is fi-6230 t driver download link?
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads/twain/
dowload your scannenr driver from above link
Feb 19, 2011 | Fujitsu fi-6230 Flatbed Scanner
Fujitsu fi-4120c scanner on Windows 7
Hi ocdaveymac
Fujitsu fi-4120c scanner drivers can be found at
driverupdate us .
enjoy
Mar 09, 2010 | Fujitsu fi-4120C Path-Through Scanner
Fujitsu FI-4220C only scans one page at a time.
The problem is not just to roll over, be changed and separation pad. These two components change very easily and boxes that are delivered and indications for replacement.
These are the codes for parts:
Pad Assembly - Part Number: PA03289-0111
Pick Roller - Part Number: PA03289-0001
After replacement counters to be reset for each Pieces. Open the scanner properties.
Usually have to display a maintenance message on the computer display, such as: separation pad should be replaced.
If there is to scan any messages like that, you have to clean the sensors around the separation pad. They are round and are getting a little inside. Click on the blue button at the top of the ADF and open the lid.
I hope you was helpful.
Aug 10, 2009 | Fujitsu fi-4220C Flatbed Scanner
Sep 19, 2007 | Fujitsu fi-5650C Path-Through Scanner
Fujitsu fi-6230 Flatbed Scanner Logo
Top Fujitsu Office Equipment & Supplies Experts
Tony
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
