Question about HP Designjet T1100ps Printer
Hpt 1100ps Grinding Noise
There is a grinding noise coming from the back right of my plotter, like a fan. Had it serviced but the plotter just didnt make the noise the day he came, so he was uncertain what it could have been. The noise doesnt occur everyday but when it does it occurs the whole day even when the plotter is idle. Any help would be appreciated.
  • Bob Wert Mar 05, 2014
    Hi Steven. I would agree with the previous poster, except for the fact that the power supply is on the back LEFT and you said the noise was comimg from the back right. The only motor that runs while the machine is not printing is the Service Station fan. You can remove the Service Station and clean out the fan motor (which is not sealed) with some pure alcohol and then use some compressed air to dry it. Also clean the fan blades the best you can. It is likely you will need to replace the Service Station which has a relatively short lifespan anyway. The part number is Q6683-60187 and can be ordered from:http://www.lpscomputer.com/p-3383-q6683-... . We refurbish the units and pay $40.00 and shipping for the return of the old mechanisms - pretty good deal. We are back-ordered on the T1100 Service Stations until next week, but you can place an order if you want to. Bob Wert, LPS Comptuer, 800-959-1575
  • 1,564 Answers
Hi Steven:
It sounds to me as if you have an issue with the power supply. Most power supplies these days have a fan built in them. When you have a grindy noise like that it more than likely is the fan going out or the blades of the fan is dirty enough to put it out of balance. Move your plotter out so you can see the back. Get down and listen carefully to determine where the grinding is coming from. Once you determine where the noise is coming from . Get a flashlight and is there are vents in that area look to see if you can see the fan blade spinning.
You may have to unplug the machine, remove the back of the printer to get to the area. If the fan blades are covered with dust. Try some canned air to blow away the dust. If that doesn't work, remove and replace the power supply. For future reference you should be doing maintenance on your printer monthly by dusting and vacuuming the open vents. You would be surprised how much damage paper dust can cause. You can look up the parts for your plotter here.
http://h20141.www2.hp.com/Hpparts/Default.aspx?mscssid=14053ECEC05440BCB6ED850FCB3C2FC0
Good luck.
Posted on Jan 18, 2013
4 Suggested Answers
SOURCE: grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Posted on Mar 25, 2008
frcs68
  • 1605 Answers
SOURCE: HP Laserjet 4L - Grinding or Growling noise when job sent to printer
goto feedroller.com
http://www.feedroller.com/Store/index.php?cPath=1_17_86_25
purchase a maintenance kit.
replace the piper pickup roller.
since the the printer is old and lots things need to be replaced. it is easier to replace all of the necessary parts when you have the printer apart.
the job is not difficult, just time consuming.
Posted on Nov 17, 2008
  • 140 Answers
SOURCE: make grinding noise
If you will notice that there is a transparent film that the printhead goes through to be able to print. That transpatent film is actually coded to be able to tell the print head in which direction and when to print characters. It is dirty and you need to take like a q-tip with isopropyl alcohol to clean it so it knows where to print and does not go back and forth to find a position to print. God bless you.
Posted on Jan 12, 2009
Grinding noise when braking
sound like brake pads worn down to metal damaging the brake rotor causing grinding noise.
Jul 02, 2013 | Subaru Forester Cars & Trucks
Hi, everyone!!!1 my pro 320 get noising .....what happening///
Is it a clicking noise? Hissing noise? or maybe a grinding noise? A pc can cause many different noises. A clicking noise generally means the hard drive is failing. You'd want to back up your data immediately and get a new drive. Hissing can be a bad fan or CD/DVD drive that needs to be replaced. Grinding noises can also be caused by fan bearings going out. You would need to find out which fan it is, and replace that fan.
Mar 21, 2011 | Computers & Internet
Grinding noise when fan spins fast
Try cleaning out the fans before going to the bother of replacing it. There maybe some debris stuck in it causing the strange noise. A can of compressed air often removes most of the dust and debris but on occassion it is necessary to open the case and manually clean the fan.
Generally if its grinding and clicking noises it will be the hard drive the fans will cause more a whirr than a grind
May 05, 2010 | Acer Aspire 5535-5050 Notebook
My refrigerator side is making a grinding noise and today I noticed that it is warm. the freezer side is fine. I have a frigidaire frs26kf6e.
Hi and welcome to FixYa, I am Kelly.
That grinding noise is usually ice build up on the evaporator coils to the point that the evaporator fan blades strike the ice build up. i.e. Possibly an automatic defrosting problem.
Here is what you can do to find out.
1. Unplug the refrigerator
2. Remove the contents from the freezer section
3. Place a fan blowing into the freezer compartment for a little over 2 hours. THIS MAKES A WATER MESS so be prepared.
4. After the manual defrosting period with the fan then reload the freezer.
5. Plug the unit back in
6. After 4 hours recheck your freezer and fresh food section temps.
7. You should no longer hear the grinding sound
It is highly probable that the ice build up will repeat. If it does then for sure you have an automatic defrosting problem and will need to service the defrosting problem. At least you will know what caused the grinding noise.
If after all of this that grinding noise you heard is still present you will have to check the evaporator fan assembly for signs of bearing wear.
If the grinding noise is coming from the compressor... bad news the compressor rotor is dragging and that requires a compressor replacement.
Your parts can be found here:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=frs26kf6e
(there are 2 missing digits from the model number)
Click on the model number of your exact model and the parts page will appear.
Thanks for using FixYa
Kelly
Apr 25, 2010 | Frigidaire FRS26KF6E Side by Side...
Makes grinding noise especially when shutting down
a grinding noise in a dryer is usually due to a broken motor coupling. Not sure however since you didnt include a model number, brand or year the machine was purchased. If you own a somewhat older model (bought from 4-6 years ago) it is most likely the motor coupling however newer models can have some other problems and usually require a service tech to come and look at.
Dec 24, 2009 | Dryers
A loud grinding noise comes from the fan area
Check if there are dust debris on the fan, it could create a grinding noise, but if the fan is clean, there could be a mechanical problem with it. Hope this helps
Dec 11, 2009 | Acer TravelMate 4200 Notebook
Grinding noise in tower
Grinding noise in tower If everything on your computer is working fine then it is probaly a fan put your ear in the back of your tower near the power cord and see if you can hear the grinding noise better if you can then your power supply's fan is going out if not its probally one of the inside fans in your tower open up your tower and see if you can find which fan it is if you dont want to do this you should probaly get a tech to look at it it's a pretty cheap fix and it can save your computer from heat dammage
Nov 07, 2009 | Computers & Internet
Hp 430 plotter
does the belt look ok? sounds like you have some rubber stuck in the motor gear.
Oct 22, 2009 | Office Equipment & Supplies
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
HP Designjet T1100ps Printer Logo
308 people viewed this question
Seeker5211
Seeker5211
