Question about Dell Computers & Internet
0gdg8y fan failure
System fan failure
HP M370n System fan failure will shut down in 5 seconds,
Return to the person that replaced the fan. Obviously it's not fixed.
Feb 20, 2013 | HP Pavilion Computers & Internet
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Replaced fan compaq presario a900 it will start then says system failure i dont have a disk what do i do
System failure indicates a motherboard problem, If this machine is old, I would think about not putting any more money into it.
Apr 11, 2012 | Compaq Computers & Internet
WHAT IS FAN FAILURE
fan failure is when the fan that cools the machine stops working.the error always tells u which fan is not working,usually the c.p.u fan or the system fan mounted on the casing,simply check which one is not rotating and change it.or(not recommended) if it is the system fan,just go to bios settings and dissable it.hope it helps
Feb 12, 2012 | IBM ThinkCentre A51 PC Desktop
I have a Lenovo A61 Thinkcentre that is about one year old. I am now hearing a fairly loud noise that comes and goes. When the system starts, the noise appears and lasts 10 - 20 minutes, then disappears....
Ok it still sounds like an fan. look for fans, one in power supply, one on cpu, one in case(frount or back), one on video card. before you start from cold unplug the fans that you can. and stop the one in power supply. then if there is no nosie you have to start pluging them back in till you hear the noise. **NOTE!!** don't run it long without fans!!( 40 secs) is long enough..
Feb 26, 2010 | Personal COMPUTER - LENOVO THINKCENTRE A61...
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
Hard Disk Failure
as the hard drive have movable parts it will fail one day.
If you defragement your hard drive monthly then it will take good care of your hard drive.
As the inspector is saying you should be ready for failure of your hard drive and you should back up your data.
Jun 19, 2008 | Microsoft Windows Vista Ultimate Edition
Dell XPS 400 Card Cage Fan Failure
dell xps 400 pentium d once i turn it on, it beeps and says "card cage fan failure" everytime i press f-1 to continue it shuts off and boot up again it does it everytime how can i fix this CARD CAGE FAN FAILURE??
Apr 22, 2008 | Dell XPS 200 PC Desktop
Computers & Internet Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
