Question about Miele CVA4070 Coffee Maker
Cva4070 metal spring clip came off the brewing unit. Is there a way to reinstall the spring clip?
2 Suggested Answers
SOURCE: small spring by brew unit popped out?
It goes underneath the front edge of the funnel on top of the unit. Remove the brew unit, take off the funnel (it will come off with a little mainpulation - it's dominantly held in place by 2 grips in front that will release with firm pressure), and you will see the small circular receptacle hole for the spring.
Posted on May 14, 2009
Waste unit is stuck and I can not remove it
The standard instructions are ... remove the waste container, water container & ground coffee container. On the front of the Brew Unit is a vertical black lever with a grey press button at bottom. Press this button and turn the lever clockwise. Then press the release catch that holds the brew unit as base and pull the brew unit. If Brew Unit is still stuck then its likely that the Unit State is not in the 'home position' and if this has occurred then its likely that that an error code would be showing. Regards
Dec 27, 2015 | Miele CVA4070 Coffee Maker
Miele cva 4075 stuck brewing unit
http://mielerepaircenter.com/miele-coffee-maker-repair
Sep 07, 2014 | Miele CVA4070 Coffee Maker
How do I install the brew unit drive for cva4070?
Make sure lever on front is turned to 8pm position. Then slide in until it clicks. Then press grey button and slide level to 6 pm position. regards
Jun 17, 2014 | Miele CVA4070 Coffee Maker
If your taking about the motor and gearbox that drives the Brew Unit .. then this is a complex job involving disassembly of the machine.
Miele cva4070 coffee maker showing fault76
Fault 76 is caused by there being too much coffee to compress . Assuming there is not a fault with brew unit or brew unit drive, then try to use less coffee (see menu settings) or grind the coffee to a finer level (see manual). regards
Jun 16, 2014 | Miele CVA4070 Coffee Maker
Miele cva4070 brew unit diagram
I have the same problem. Did you ever figure out where it goes
Jul 01, 2013 | Coffee Makers & Espresso Machines
Where to put the silicone/oil into brewing unit
Hi. Spray the piston guide slides in the brew unit. As the brew unit moves up and down, you'll see the piston being guided. Rince with water 1st. Use a silicon spray that dries clear. not that white sticky stuff. It just collects coffee grounds and jams the piston. Dazza REPAIRER
Sep 23, 2011 | Miele CVA4070 Coffee Maker
Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Apr 13, 2010 | Miele CVA4070 Coffee Maker
Not making espresso from beans
Hi
Are your coffee grinds wet? If they are you have a clogged brew head. Remove the filter screen. Then remove the 2 screws that hold the outlet manifold to the brew head. There are 3 things under the manifold. O-ring, tapered spring and a crystal ball. Don't lose any of these items. Now to clean the brew head turn the brew unit over to where you can see where the brew screen was. You will see 2 holes, 1 large and 1 small. Take a paper clip and straighten it. Turn the brew unit upside down and insert the paperclip into the small hole. Push the paper clip through and remove the plug. I have seen them over 1/2" long. Reassemble the brew unit crystal ball first, small end of the spring on top of the crystal ball, place the o-ring over the spring and place the manifold on top making sure the outlet pipe is to the outside of the brew unit. Put the 2 screws back and your ready to go. Run a detergent for espresso machines like Cafiza through the brew unit every once in a while to keep it clean. It doesn't take a lot of detergent and use the pre-grind setting and a large cup selection but don't put any coffee in.
Nov 25, 2008 | Saeco Royal Digital Plus Coffee...
Miele CVA4070 Coffee Maker Logo
63 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
