Question about Eclipse (FUJITSU TEN) Advanced Function CD/MP3 In-dash Player (CD5000)
Wiring harness for av3423mt - Eclipse (FUJITSU TEN) Advanced Function CD/MP3 In-dash Player (CD5000)
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
Feb 07, 2016 | 2001 Subaru Legacy
How many wire harness clips connect to module besides the antenna
Engine Control Module Wiring Harness Replacement - 1.4 L ...
workshop-manuals.com/.../repair.../engine_control_module_wiring_harn...
3. Unclip the 3 wiring harness clips (1, 2) from the engine control module wiring harness brackets. ... Disconnect the wiring harness connection adapter plug (4).
Engine Control Module Wiring Harness Replacement - 1.6 L ...
5. If equipped, disconnect the engine oil level sensor wiring harness plug (7). ... 10. Unclip the 2 wiring harness clips (2, 6) from the wiring harness brackets.
How to fix wires that break out of plug clips on a wire harness
Dec 01, 2015 | Cars & Trucks
Trouble shoot
I believe that's a Speed Sensor issue.
Diag:
1. Ensure mainshaft and countershaft speed sensors are installed properly. Disconnect mainshaft speed sensor harness connector. Using a DVOM, measure resistance between sensor terminals.
2. If resistance is not 400-600 ohms, replace mainshaft speed sensor. If resistance is 400-600 ohms, disconnect 25-pin PCM harness connector "B". Check for continuity between ground and 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
3. If continuity is present, repair short to ground in Red or White wire between PCM and mainshaft speed sensor. If continuity is not present, reconnect mainshaft speed sensor harness connector. Measure resistance between 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
4. If resistance is not 400-600 ohms, go to next step. If resistance is 400-600 ohms, go to DTC
P0720 (FLASH CODE 9) . Check for loose PCM harness connectors. Replace PCM with a
known-good unit if necessary.
5. Disconnect mainshaft speed sensor harness connector. Check Red wire for continuity between 25-pin PCM harness connector "B", terminal No. 15 and mainshaft speed sensor harness connector. If continuity is present, go to next step. If continuity is not present, repair open in Red wire between 25-pin PCM harness connector and mainshaft speed sensor
harness connector.
6. Check White wire for continuity between 25-pin PCM harness connector "B", terminal No. 14 and mainshaft speed sensor harness connector. If continuity is present, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary. If continuity is not present, repair open in White wire between 25-pin PCM harness connector and mainshaft speed sensor harness connector.
Mar 21, 2014 | 1998 Acura Integra
Car
Speed Sensor probably. Try:
harness connector.
Mar 21, 2014 | 1998 Acura Integra Type R
03 ford expedition audio wiring diagram
sounds like a faulty instrument cluster
Nov 20, 2017 | 2003 Ford Expedition
Wire diagram for the a/c cooling fan.. 1991 Jeep Commache
I am sorry but fixya doesn't have any wiring diagrams. They are copyrighted and not free to share.
Jul 22, 2012 | Jeep Comanche Cars & Trucks
I have a 2004 Hyundai Elantra and am trying to install a stereo but dont know what the wiring diagram is..any help?
Personally owning this car and installing several Hyundai stereo's, I would purchase a wiring harness kit from car audio shop or electronics retailer. The wire harness has a plug that connects to the cars wiring harness. This wiring harness kit will also list the wires to connect your new aftermarket radio to the harness. I would also recommend using crimped **** connectors to attach the two harnesses together.
Feb 24, 2010 | 2004 Hyundai Elantra
How to hook up the pioneer stereo to wire harness?
Not real clear on question, but you can buy a direct fit wire harness and the wires are color coded so you don't have to cut and splice your wires on your factory harness.The harness hooks to your factory plug and you wire it to your pioneer stereo wires. Harness is about 7.99 up at most stores.
Nov 03, 2009 | Boss RT-6CK Car Component System
Wiring harness
I Have the wiring harness and can get more of them. Email me @ jetski0224@aol.com if you want one Jensen vm9510 harness
Oct 10, 2006 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
27 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
