Question about Dwyer Handheld Manometer, 0 to 20.00 In WC - 475-1-FM
Dwyer 475 out of tolerance how do you adjust it
Two screws inside battery compartment. What do they do? is one range one linearity? Or one inH2O other kpa?
I have a 1999 Mitsubishi Projection TV and the vertical hold wont adjust. How do I reset it.
Put it back to the mid point of it's adjustment range.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced.
Sep 10, 2014 | Mitsubishi Televison & Video
Vertical hold problem on 1999 Mitsubishi rear projection VS 50605 can't find reset button.
Sep 10, 2014 | Mitsubishi WD Televison & Video
Sony vaio pdc-8x2l disassembly
The cover above the keyboard might be secured by screws inside the battery compartment. Just remove all the screws from the bottom of the laptop, but check inside the battery compartment, hard drive compartment, dvd drive compartment, memory compartment and wifi compartment for screws once you remove them or remove the cover.
May 09, 2012 | Computers & Internet
Have a whirlpool super capacity 465 and when we turn the oven on, the flames come up into the oven compartment. how do i adjust the flames. It doesn't have a screw or nut to adjust
It does have a conversion nut you remove and flip over for LP. And then on that same gas distribution valve is a adjustable orifice toy tight down to lower them flames Mon Ami. See page 5
Dec 19, 2010 | Whirlpool GS460 Gas Kitchen Range
How do I calibrate the scale
Make sure the chair is clean and there is nothing between the chair the sensors. Put the setting to zero. if it the arrow goes to center you are good. if not you have to adjust the screw on the other end of the beam. Make a quarter turn at a time. Don't go crazy with it. Try to get the arrow to zero as close as possible. push down on the chair a few times times to make sure it is consistently gets to zero. Get several different weights to check the linearity, 10 should equal 10. 20 should equal 20 and so forth.
Nov 10, 2010 | Detecto 475 Beam Chair Scale
I need to change the gear selector knob how does
Shift Control Linkage The transmission range selector control linkage consists of the following components:
  • a floor mounted transmission range selector lever.
  • a transmission control switch on the transmission range selector lever.
  • a cable connecting the transmission range selector lever to the transmission manual control lever.
  • a brake/shifter interlock system.
  • an ignition/shifter interlock cable (3F719) connecting the reverse kick down spring (7219) to the steering column lock assembly.
Section 07-05: Transmission, Automatic—External Controls 1996 Mark VIII Workshop Manual
REMOVAL AND INSTALLATION Gearshift Lever Removal
  1. Place transmission range selector lever in OVERDRIVE. Remove console finish panel (04567). Refer to Section 01-12 .
Console Panel, Floor Removal and Installation
  1. Remove gearshift lever. Refer to Section 07-05 .
  2. Remove center A/C-heater instrument panel finish panel (04338).
  3. Remove instrument panel finish panel (044D70).
  4. Remove two screws retaining console finish panel (04567) to radio control cover (04530).
  5. Unsnap RH rear corner of console finish panel and then disengage three retaining clips from LH rear corner.
  6. Disconnect cigar lighter socket and retainer (15055), lamp and switch connectors and remove console finish panel.
  7. Remove two screws retaining console panel (045A36) to instrument panel (04320).
  8. Open glove compartment door (06024) and remove console glove compartment mat (047A74) in bottom of console glove compartment (06010) to gain access to two console panel-to-instrument panel console bracket retaining screws. Remove screws.
  9. To remove, slide console panel rearward and up.
  10. To install, reverse Removal procedure. Tighten screws to 1.5-1.9 Nm (13-17 lb-in).
Item Part Number Description 1 046A44 Radio Finish Panel Assy 2 047A74 Console Glove Compartment Mat 3 045A36 Console Panel 4 N804234-S36 Screw (2 Req'd) 5 N800322-S36 Screw (2 Req'd) 6 N805180-S58 Screw (2 Req'd) 7 N806577 Nut (2 Req'd) A — Tighten to 2.5-3.1 Nm (22-27 Lb-In)
  1. Remove brake interlock cable and disconnect cable from range interlock cam.
  2. Disconnect transmission range indicator lamp/TCS electrical connector.
  3. Raise vehicle on hoist. Refer to Section 00-02 .
  4. Remove range cable retaining nut from transmission bracket. Disconnect shift cable and bracket (7E395) from transmission control selector connecting rod adjustment stud (7B415).
  5. Lower vehicle. Remove range selector lever and housing retaining bolts and remove gearshift lever (7210).
Installation
  1. Install transmission range selector lever to front floor pan (11135) with retaining bolts. Tighten to 6-8 Nm (4-6 lb-ft).
  1. Connect shift cable and bracket. Tighten retaining screw to 3-4 Nm (25-35 lb-in). Install retaining clip and connect transmission range indicator lamp wire.
  1. Install console finish panel.
  1. Place the transmission range selector lever in OVERDRIVE and apply a 1.4 kg (3 lb) rearward force to the lever.
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. Connect theshift cable and bracket to the manual control lever (7A256) and transmission bracket. Make sure manual control lever is in OVERDRIVE and tighten nut at bracket to 13-25 Nm (10-18 lb-ft).
  1. Lower vehicle and check range selector for proper operation.
Dec 07, 2009 | 1994 Lincoln Mark VIII
Oven temperature adjustment
well no need to fret, if you oven is heating over 100 degress off theres problably not an adjusatment to compensate for that, youll need to either replace the htermostat or the thermistor, depending on which your machin uses
Jan 18, 2009 | Hotpoint RGB745 Gas Kitchen Range
Directv RC32 remote
Hey DM - Did you remove all 3 screws under the battery cover? The two little black ones near the bottom and the one up inside the battery compartment? Thanks.
Jeff
Aug 11, 2008 | Toshiba Satellite A105 Notebook
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Both Screens Flicker after trying to replace touch screen
I finally solved the flickering problem on my DS (!), after I made my 1st engineering attempt overhaul shell, top screen and broken right hinge.   Was really frustrated about the flicker afterwards, and opened up unit back up too many times to debug (risked damage to cable ribbon everytime!).
Anyway turns out there's 2 hidden screws (location:  inside the battery compartment near where the front 'volume slider' is located) that adjusts the flickering (like how you need to calibrate an LCD monitor from doing same flickering effects) . You'll need a really (really!) small philips (+) screwdriver to do the adjustment.
Open up the battery cover with the VOL label upside down & facing you.  The adjustment screws are recessed deep inside the plastic...a right and left screw.  With the DS turned 'ON' to see the screen (whether you twist your neck to be able to see or have a mirror on the table in front of the DS)....slowly/carefully turn the screws to adjust until you like the clarity.  That's it.   The right screw = bottom screen.  The left screw = top screen.
Now.... on to figuring out how to replace or fix the broken Power toggle switch that I snapped off!  Currently using the toothpick method, but that's getting old!  Any suggestions, I'd appreciate it!
Dec 08, 2007 | Nintendo DS Lite Console
Dwyer Handheld Manometer, 0 to 20.00 In WC - 475-1-FM Logo
32 people viewed this question
Top Dwyer Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Dwyer Science and Laboratory Expert? Answer questions, earn points and help others
