Question about Vacuums
Blown fuse in a hoover platinum carpet cleaner
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
SOURCE: hoover steam carpet and upholstry cleaner
I have a model F6211. On mine you have to remove the hose caddy and the door is under it.
Hope it helps.
Posted on Mar 09, 2009
SOURCE: Hoover SteamVac Dual V Carpet Cleaner # F7410-900
"I did some research online and the recurrent theme was a bad turbine assembly. Fortunately I was able to fix this myself which took about 2 hours (some reading) and little effort. The problem was with the turbine which is fairly simple and had a bearing that had rusted and froze up. Removing the cover proved to be more difficult than fixing the stuck bearing. This was mostly due to figuring out the correct screws to remove and finally discovering that the back of the cover (over the wheels) is not secured by fasteners but by pegs that "pop" out.
Once I had the brush assembly and Cover removed the turbine came out with the removal of some obvious screws and gently pulling the hoses from the assembly. After carefully opening the assembly housing I discovered the bearing problem and with a little lubrication and some new grease had it working in short order. Putting everything back together was simple as well."
this worked for me. although once i got in i just had to mess around with the gears and loosen them up. getting in was the hard part soo here you go peoples.
take off tanks
unscrew 6 screws fom underneath machine. look carefully
just underneath where the dirty tank goes right by the part that sucks everything up is a screw. unscrew it
pop off the switch for your spin scrub mode. it pops right back on.
make sure your locks for the tank are turned in
then the back just pops off. you might have to give it a good tug. there are no screws although it maight look like there is.
then pull off the grey part.
once inside it is pretty easy.
but if you have any questionbs email at lostnhisblueyes@aol.com
i took off so many more screws than i needed to to get this figured out so dont do that.
Posted on Apr 03, 2009
  • 294 Answers
SOURCE: Where can I find a user manual for a Hoover Steam
The manual can be downloaded at Hoover.com for your exact model
Posted on Oct 11, 2009
  • 190 Answers
SOURCE: hoover carpet cleaner not picking up water
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
In addition, make sure the recovery tank lid is properly aligned to the tank to seal.
Lastly, make sure the square duct is latched in place in front of the recovery tank, that links the nozzle plate to the tank lid.
Posted on Mar 15, 2010
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Help! My boyfriend took apart my hoover platinum carpet cleaner
That sucks! Um, if you do not have the manual, here it is
http://hoover.com/file/622/
If that does not help. you can contact Hoover
https://hoover.com/contact/
Flick the boyfriend
May 08, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover max extract brushes wont spin
Check that the brushes are not jammed up with hair and fluff.
Remove the brush from the housing and clean throughly including the bushes/inserts and belt
Hope that helps
Feb 09, 2014 | Hoover Platinum Carpet Cleaner With...
I have hoover platnium collection vacuum the lights turn on but does not run
If you are electrical handy, check for wiring continunity to motor or the motor itself could be bad. Only do this safely.
Dec 02, 2013 | Hoover Platinum Collection Carpet Cleaner
My Hoover SteamVac carpet cleaner leaks water
i have a hoover carpet cleaner and when it is not in motion it leaks water
May 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Hoover turbo cyclonic only 12 weeks old stopped working while cleaning. I was using the hand tool and after about 3 minutes it just stopped and will not turn back on.
try changing the fuse in your plug ( uk ) if this fails to fix it , have it repaired under warranty
print-icon.gifPrint/Download
Warranty The Platinum Collection Lightweight Bagged Upright plus Portable Canister warranty covers parts and service of the cleaner for six years.
As a member of the Hoover Platinum Collection, the Platinum Collection Lightweight Bagged Upright warranty gives the owner access to the exclusive Platinum Collection member services line for the best in customer service.
TTI Floor Care North America
7005 Cochran Road
Glenwillow, OH 44139
1-877-MY-PLTNM
Nov 15, 2009 | Vacuums
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Which is the best caprpet steam cleaner mid priced?
I would recommend the Hoover brand. The Bissell's are very problematic, they have belts that break and issues with the heating elements. Hoover Steam Cleaners can be repaired and are simple to use. The price range is generally $180 - $300
Jan 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
89 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
