Question about Samsung Heating & Cooling
Samsung asv09esln air conditioning showing e1 01
ASV09ESLN
What do you want to know? Reformat? Are you looking for set-up codes and set-up procedure to sync: it with your device. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 11, 2014 | Televison & Video
Greeting, I have problem with SAMSUNG air condicioner inverter. The display shows me an error E1 A1 and does not include the external unit, please help what is the problem.
E-1 Room sensor and A1 Indoor PCB fault. Please you replace first,indoor sensor and reset.Sometimes indoor pcb shows fault code due to sensor short. After replacing sensor it will show only A! or sometimes no error. If it shows A1, you have to repair/replace PCB. Helpful?
Jan 24, 2011 | Samsung AW1203B Air Conditioner
I am getting E1 error in my window Samsung 1.5 T a/c can u please hep ?
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Aug 30, 2010 | Samsung AW0503B Air Conditioner
Amana air conditioning unit
You either have a blower that is gone out,or the start capacitor is bad,it is most likely the blower motor.
Jul 18, 2010 | Samsung AW1203B Air Conditioner
Size of air condition.
Get the cubic volume of the room. The highest temprature differential. and how many air changes you need. this will give you the btu required.
If this is too high, get the biggest unit that your supply can safely carry.
Mar 27, 2010 | Samsung AW1091L 10,800 BTU Air Conditioner...
Code E1 on my Samsung AW1204B Air Conditioner
Found this on Samsungs site.Hope it helps a little, at least you know the problem now.
If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced.
If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced.
To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have the model number of your air conditioner on hand when you call.
Feb 03, 2008 | Samsung AW1203B Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
