Question about Mitsubishi VS-45607 45" Rear Projection Television
Tv turns on with difficulty
Mitsubishi VS 5004R rear projection TV. It takes many attempts with the remote or from the power button of the set for the tv to turn on. I can here a relay click each time the power button is depressed, but the set will turn on only after the first click is followed by a louder click. What can I do to repair this????
  • Kai Joe Jul 13, 2007
    It does'nt matter when it's hot or cold or if it's been unpluged for days. the problem is consistant. You can depend on the tv to turn on only with a dozen or two attempts. I need specific instructions for repair.
    President:
  • 3,130 Answers
This is an older Mitsubishi projection TV set and does not have a fan or a bulb to go out. These sets are very common for the caoacitors in the power supply and the sweep power supply to go bad. To find these bad capacitors, you will need the service manual, and you can download that here:http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=%20VS%205004R. You will also need to get a capacitor checker to check the capacitors in circuit, and thats called an ESR meter. There is simply no easy way to fix this TV set without doiing these steps.
Posted on Jul 13, 2007
  • 944 Answers
First try unplugging the set from the wall completely for about 20 minutes. Does the TV function normally from the buttons on the set itself?, just to eliminate any possibility of the remote being the problem. If you disconnect all the inputs that go into the set, do you get the same problem? How many hours do you have on the lamp approximately - usually if a lamp has problems, it wouldn't be intermittent or occasional, but if the lamp is nearing its expected life span, then it is just possible. Removing and reinstalling the lamp may be worth a try, just in case there is a bad contact. Does it seem to work more easily when the set is warm? If the relay itself is ok, which it sounds like it is, then the problem is most likely in the power supply somewhere, especially if it appears better when the set is warm. I had no luck finding a user manual or service manual for this set online - if you have one somewhere check to see if there is a "reset" function for the set - I'll keep looking. Are you able to open the set up, firstly to identify the relays in question and check them, and also to inspect the power transformer and associated circuitry? Waiting for your info, Hope this helps :)
  • Nigel Ridehalgh
    Nigel Ridehalgh Jul 13, 2007
    PS - does the cooling fan start up from the first relay click, or the second - if you get no fan sometimes, then the problem could well be there - there is usually a protection that stops the set operating if the fan is not running.
How to turn on tv
Hello, try holding the power button for 5 seconds and see if it will come on, otherwise try a universal remote programmed to a mitsubishi tv. If it still won't come on it might have a problem in the power supply....tks
Nov 08, 2013 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
I have a Mitsubishi VS-5004r 50? TV. Two
Brian:
Have you just tried to unplug the A/V for an hour or two and then re-plug the power back in and try turning it off to see if this 'power off tactic' cures the problem?
The reason for the code is for a qualified service tech to go into the service menus for adjustments.
web site below about the code issue: http://www.answerbag.com/q_view/965160
Blessings,
A/V Media Tech Guy
Dec 01, 2009 | Televison & Video
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Tv not coming on
try removing batteries from all remotes, a faulty remote may be turning your TV on/off. If it still does this, there is a power problem and you likely need a tech to look at it.
Dec 09, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Lockout
have a tech lift off the eeprom or the microchip out of the set,that will rset your tv.and bring it back to normal.good luck.
Apr 06, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS50603 will not turn on
If you are not a tech the tv needs to go to a tech to be fixed.the probleis in the power supply or related circuit good luck.
Apr 01, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
