Question about Microlife Deluxe Wrist Blood Pressure Monitor Bp3nc1-1W
SETTING USER TWO MICROLIFE BP3NC1-1W
CAN NOT SET USER TWO
Clear memory for second user on blood pressure monitor
Try pressing the start stop buttons at the same time. If this is not correct you can call toll free for tech assistance, here is the number:Toll Free Help Line: 1-800-568-4147
Aug 15, 2016 | Microlife Health & Beauty
How do I clear the memory on a Microlife 3MC1-PC blood pressure monitor?
Turn it off, Hold down the "M" button until "CL" appears and press "M" while "CL" is flashing.
May 09, 2015 | Microlife 3MC1-PC Blood Pressure Monitors
Cuff does not get full inflated even after getting it properly applying error3 appears,I m a Doctor
replace batteries,or there is a leak,you didnt say which bp machine it was so go here and find your machine to get the user manual for it, Microlife Manuals
Apr 02, 2015 | Microlife Health & Beauty
I need manual for BP3GX1-5X
It's at the bottom of this page: http://www.costco.com/Microlife%C2%AE-Deluxe-Arm-Blood-Pressure-Monitor.product.100040973.html
Mar 10, 2014 | Microlife Health & Beauty
I missplaced my manual and don't remember how to set it. What numbers should I be looking for so I will know if my blood pressure is normal or high
Their site list a manual for the 3AC1-PC here. If this is not compatible with yours, contact MicroLife directly:
Toll Free: 1-800-568-4147 for blood pressure and thermometer support.
Toll Free: 1-888-934-1839 for peak flow meter.
Email: custserv@microlifeusa.com
You can reach customer service 8am - 8pm, Monday - Friday, (Eastern Standard Time)
I hope this helps!
Feb 05, 2013 | Microlife 3AC1 AP Premium Blood Pressure...
Setting date and time
go to menu
go to settings
go to date and time
and set the time
hope it help
May 10, 2012 | Microlife 3AC1PC Premium Blood Pressure...
Program date and time on the microlife bp monitor
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Jun 08, 2009 | Microlife 3MQ1 Blood Pressure Monitor
Microlife Deluxe Wrist Blood Pressure Monitor Bp3nc1-1W Logo
42 people viewed this question
Top Microlife Health & Beauty Experts
Colin Stickland
Colin Stickland
Jerry Kramer
Jerry Kramer
Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
