Question about Philips GOGEAR SA6045 MP3 Player
Format player player problem connect player to pc format player
  • 8,596 Answers
Use the Philips Device Manager to run a Repair on your device - it will give you instructions, and enable you ti fix your player.
-Tha Mp3 Doctor
Posted on Feb 07, 2009
My Philips GoGear SA011 just says "No songs found" in Music/All songs.. everytime.I can only play music in Folder/Music/.. I have updated the newest Firmware for SA011 but nothing else happen. What is...
Back up your player before you format it. Formatting erases all the data inside your player.
  1. Connect your player to your PC.
  2. On your PC desktop, double-click My computer.
  3. Highlight your player in the popup window, right-click, and then select Format.
    If you don't see the Format option:
    • Double-click on your player in the popup window.
    • Highlight the Internal Storage icon, right-click, and then select Format.
    • Click Yes when you see the warning message.
  4. Click Start to format your player.
  5. When the formatting is finished, copy your music, pictures and video onto your player.
Aug 04, 2010 | Philips GoGear SA261 MP3 Player
When turned on the screen displayed FAT is
First try to reset the player 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry -- For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player **** If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. ***** Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the player. It is usually the last device listed. Right-click on the player and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa Clip MP3 Player
I can't get certain songs to delete off the mp3 player. I'd like to delete all songs and start over.
connect it to your pc and use the format option to completely wipe the memory, connect to the pc Start, Computer, Right click on the mp3 player icon and select the format option.
Dec 02, 2009 | RCA OPAL M4001 MP3 Player
I have the same problem.
this time you are reformatting that player, i think that connection between is malfunction...
Jun 16, 2009 | Sony NWZB133F MP3 Player
Message showing - player problem connect pc and fformat player
i have philips gogear sa 1356/97 mp3 player.it is not working .when i switch on the player a message displays "Player Problem-Connect to pc-format player". My PC not detecting the device.
Jan 19, 2009 | Philips GoGear SA1350 MP3 Player
FORMAT PLAYER
Use the Philips Device Manager to perform a Repair
Sep 09, 2008 | Philips GoGear SA178 MP3 Player
FORMAT PLAYER
may be u dont have windows XP service pack 2 installd... install it thn try to connect./
Aug 27, 2008 | Philips GoGear SA178 MP3 Player
Corrupt playlists
Connect the player to the power supply and PC.
Press and hold [Vol +] & [POWER] until player resets.
As soon as the screen goes blank, release [Vol +] & [POWER] and press and hold [Vol -].
Player should show the connection screen, but without the status line at the top
PC will recognise the player as a removable drive.
Once the PC says that the device is ready to use, open My Computer and player should be in the list. (GoGear)
Right click on the player and select format.
Tick the "Quick Format box" and make sure the format is FAT32, and click start.
When the player has formatted, safely remove, and power up. You will get an error message on the player saying "connect to PC".
Connect to PC normally and repair with Device Manager.
Feb 25, 2008 | Philips GoGear HDD6330 MP3 Player
T-Sonic 610 display
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Oct 03, 2007 | Transcend T.sonic 610 MP3 Player
Mpio fg200
Turn off the unit and connect it to the computer.
The computer should recognize the player.
Run a program called Mpio Utility (Can be found on the CD or Mpio.com)
Select format & Config
That should do the trick.
Or go to www.mympio.com
Feb 01, 2007 | Mpio FG200 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
22 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
