Question about Belling 335 Electric Kitchen Range
I HAVE A BELLING ELECTRIC COOKER AND ON THE BACK IS A BLACK BOX CONTAINING PUSH ON ELECTRICAL WIRING.DO YOU KNOW THE ORDER THESE ARE FITTED tHANK YOU
  • Anonymous Jan 25, 2009
    there are 9 wires; 2x yellow and green;2 x grey 3x blue 1 x brown 1 x yellow; the black box is marked 12345 and earth do you know which wires go where
    Thanks
    President:
  • 1,214 Answers
It should be marked Line 1, Line 2, and ground or neutral. If it's ground, it may be the little ground graphic.
Posted on Jan 25, 2009
Belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
i,e,
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
May 08, 2012 | Belling XOU174 Electric Single Oven
Need to know if my cooker is a bayonet fitting
the bayonet fitting is on the end of the gas pipe that plugs into the gas main. look at the back of your cooker follow the black pipe you will see a brass end that fit to the solid gas pipe if you have a ring on the end of you flexible pipe that you can push in slightly and turn to disconnect you have a bayonet. its not the cooker that is a bayonet but the flexy pipe that is connected to your cooker. you can add one if one not fitted
Feb 02, 2010 | Belling Solitaire G755 Gas Kitchen Range
Correct cable size for belling cooker fitting
If this is a fan assisted oven then a 2.5mm twin and earth is sufficient, but please consult the manual and let me know the wattage, or contact a qualified electrician.
Nov 25, 2009 | Belling 335 Electric Kitchen Range
Hardwiring in cooker
6mm is the norm for wiring in the majority of electric ovens, you could fit 10mm, but it is is not really needed, unless you want to do it that way.
Please rate my fixya solution.
Thankyou.
Jan 30, 2009 | Belling Ovens
WIRING FOR AN ELECTRIC COOKER (I NEED A DIAGRAM) !!!
Trying to wire up an electric oven. Good with electrics, normally. Sounds stupid bus there are no holes to place the wires into on the oven panel. In other words not like the speces on a plug or on the main live circut on the wall. Where do I put the wires????
Sep 28, 2008 | Belling XOU174 Electric Single Oven
Belling Format cooling fan
i assume you mean the casing fan and not the fan inside the oven.
this is controlled by a fan stat which is inside the casing. cheap part and easy to fit. iv forgotten the exact location but remember it located at the top
Jul 03, 2008 | Belling 644 Electric Kitchen Range
Fan won't switch off
sounds like the contactor /power relay went.they supply voltage to the motor.trace the wires from the motor back to find them.
Oct 28, 2007 | Belling 644 Electric Kitchen Range
Oven not working properly
It may be the oven thermostat needs replacing.
Jan 29, 2007 | Belling 644 Electric Kitchen Range
Belling 335 Electric Kitchen Range Logo
331 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
