Question about Whirlpool GS475LEKS Gas Kitchen Range
Gas oven wont stay on
Belling gas oven lights ok but wont stay on when button is realised
    President:
  • 1,214 Answers
If this is electronic ignition, then chances are the burner or ignitor nub has residue on them, preventing the flame detection system from keeping the gas on.
Use warm soapy water and a plastic scrub brush to thoroughly clean the burner cap, burner base, and ignitor nub.
Posted on Jan 25, 2009
Belling cookcenter oven over heats and light stays on
It sounds like the people who changed the elements did not connect them to the correct wires. The thermostat seems to have no effect on the elements, and the light switch seems to have no effect on the light, explain this to them and that you think they fitted the elements directly onto the power input to the device, instead of the correct connections.
Dec 14, 2013 | Ovens
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
Hi there, I have a belling gas oven cooker, which when you try to ignite the oven or grill it keeps ticking but wont spark up. The gas is fine as you can light them manually and the hobs light fine so...
why would they be trying to light an electric oven ( see which product do you think they mean ) You need to check that the spark being produced is close enough to the gas outlet
Oct 03, 2012 | Ovens
Oven wont stay lit
If you are talking about the little flame that is supposed to be burning at all times then you need to go to a hardware store and purchase a thermocouple. It is a small copper tube that sense's the flame. When working it will constantly burn a pilot flame so that when you turn on the oven it will ignite the gas in the burner. Once the burner is lit it will stay lit until the oven reaches the desired temperature. Replace the THERMOCOUPLE.
Sep 09, 2011 | Belling Solitaire G755 Gas Kitchen Range
The main oven flame wont stay on when lighting
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 06, 2010 | Belling FarmHouse 931 Gas Kitchen Range
Belling Farmhouse Cookcenter Model 111 main oven wont reach temp
Same problem here too. Plus the in-game assisted oven has a similar problem inasmuch as the flame goes straight to max and won't reduce. Please help
Apr 05, 2010 | Belling FarmHouse 931 Gas Kitchen Range
Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
Oven won't stay lit
gas oven ignites and lights then flame goes out
Jun 17, 2009 | Belling Solitaire G755 Gas Kitchen Range
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Oct 31, 2007 | Ovens
Whirlpool GS475LEKS Gas Kitchen Range Logo
349 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
