Question about Jenn-Air JXT8142ADS Kitchen Hood
Venting hood to outside wall.
I'm having my siding done soon and i need to install my hood which will vent out a side wall
  • 142 Answers
Install ducting along with closing flap (so outside wind does not blow in) and power first !
Posted on Jan 25, 2009
How to vent exhaust outside
bea12bfe-3a65-4764-8544-5bc63391c2dc.jpg9dbdeaa6-0b81-4926-ab21-2206dc8f6420.jpg6bfcce66-f35e-4950-b5c4-5ba9eff2c34c.jpgI usually choose an outside wall if possible to vent outside. You can buy a rear vent that is superior to a dryer vent. When this isn't possible you need a rectangular duct going up through your cabinet and up through your ceiling. hopefully you have an attic or you have to switch to a 5 inch tube going sideways (above your cabinets (if there is space) to the outside wall. If it goes into an attic you have to cut through the shingles to a vent made for bathroom and or hood vents. The motor and blower assembly inside your microwave is designed to turn to be front facing, rear facing or vertical facing. Just unscrew or break out the side that you need to vent through.
Oct 21, 2013 | GE Spacemaker JVM1540 Microwave Oven
Cooker hood installation
A cooker hood needs to done by a competent qualified Electrician but basically depending on your surface of the cooker hood.Depending on the type of cooker hood you have(extract or outside) If it is a extraction (meaning you are using filters and not connected to a vent) The Electrician needs to connect the electric to a point or spur via a power switch on the wall which when you fit up the main part of the hub covers the spur. after that you need to measure and fit the cooker hood to your requirements but make sure your walls can support it and mark off the holes before drilling or check the walls for electric wires in terms of safety.
May 21, 2012 | Washing Machines
We have a Kenmore builin icrowave with exhaust hood over the range. The exhaust fan appears to recirculate the air into the kitchen and not sending it out. This causes the cooking smell to remain inside...
some fans have a charcoal filter that needs replacing others are supposed to be vented out side by the roof or out the wall to see if the vent is going outside you will have to unmount the unit tak it down and check and see if it is conected to a duct in the celing or through the wall hope this helps
Mar 09, 2011 | Kenmore Microwave Ovens
How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Phil
Apr 10, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Need to side vent LG dryer
if you have an opening on the side then yes you can shorten the stiff tube that comes out the back but i recommend you get a stiff elbow to make the turn and add whatever is needed to come out the side then attach the flexible to the wall. that's the safe way of doing it. That air is pretty hot in the cabinet
Mar 01, 2009 | LG DLE5977 Electric Dryer
How do i fit the flue to the wall?
The flue fits through the wall and fits to the vent on the outside, the vent should be screwed to the outside wall.
Feb 22, 2009 | Smeg KSED65X-1 Kitchen Hood
Change the venting from internal to external?
Hello staufferbi,
It is possible to redirect the vent to the outsied but it is not a simple task. First off, you will need to remove the micro from the wall cavity and reposition the blower so that it vents out the top and not the front, then cut a hole in the cabinet above the micro ( lined up to accept the rectangular duct ) These tasks require fairly good carpenmtry skills and may not be suitable for the novice.. In any event, if you do attempt this.. then once you have the duct vented through the cabinet from the top of the microm you will need to attach that to wall vent feedthru. This normally means converting the rectangular duct to 4inch round and using an elbow. Needless to say, it can be done but is fairly involved. I did not mention anything about getting a 4 inch hole thru the outside wall and not thru a wall stud.,. Outside walls are typically bearing walls and although your roof won't cave in if you cut a hole thru a stud, it isn't advisable. Then you have to make sure it is sealed thru the wall cavity and properly cut into your siding. As I said before..it can be done but don't think it is a little job..
Good luck
Rick
Jan 09, 2009 | Microwave Ovens
No Exterior vent for fumes
Hello kbender,
I am absilutely certain that the reason it vents inside is because it is more difficult to vent it outside.. ( which means it costs the builder more to do that) but to answer your question.. Yes, all spacemaker micros can be vented out the wall but you will have to remove it from where it is mounted and rotate the blower assembly so it vents out the back, place a blank off plate over the open area where it used to vent ( it may be there and needs to be repositioned when you rotate the blower) , then create a vent hole that lines up with the exit point of that micro.. and attach duct work to bring it outside ( depending on your siding , will dictate how that gets mounted externally and you may run into a problem witha stud on the outside wall ( a bearing wall) that wil need to be cut..I've installed many of these to outside vents and it is a lot of work.. so you may want to consider your options. If you hire someone, that's the easiest solution. You may also want to check to make sure your condo committee ( if you have one) will not have a problem with that.. or you may be able to get a group discount if you hire someone to do mulitple units..
Hope that helps..
Regards,
Rick
Dec 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave range hood install -- stud in middle of exhaust
You have a few options, First off, I am assuming that the stud you refer to is an outside wall. Assuming that is true, then you have a few options.... one of them is to cut thru the stud and run the vent out. Even if that stud is on a bearing wall ( meaning it is carrying a roof load above it) ... It is unlikely to pose a problem if that one stud has been compromised with it cut out, If that concerns you.. and you are handy, you can open that area of wall up from the inside and box the area that the vent will be located in with short pieces of 2x4 to the studs on either side of it... Another option is to vent the hood up thru the cabinet above and direct that out slightly offset to the stud in the wall..
One thing I have done is to cut the stud out and then to place a piece of 1/2" plywood in the area that the micro/hood will be located and attach that piece with drywall screws to the studs in the wall.. That piece of plywood will help support the stud you cut when you screw it to the adjacent studs and also act as a place to secure the hood mounting bracket on the wall. Granted, it shifts the hood out from the wall 1/2 " but then you have plenty of surface to secure the plate and don't have to worry about hitting a stud or using wall anchors.. I hope you understand my comments..If not...please respond to this and I will provide additional information to clarify this... Hope this helps !
Aug 13, 2008 | Hotpoint RVM1635 Microwave Oven
Kitchen hood
Yes you can , usually they got hole on top too , just make sure when its done that the air is going out and it will be fine . I
Aug 22, 2007 | Whirlpool (RH3736XLS) Kitchen Hood
Jenn-Air JXT8142ADS Kitchen Hood Logo
325 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
