Question about Diablotek RADEON 9550 Video Card - 64MB DDR, AGP 8x, DVI, VGA, TV Out, Video Card Graphic Card
Need vid card 4 dos
I'm looking for an agp vid card that runs in DOS. Suggestions?
  • cyanidehole Jan 26, 2009
    Thanks a lot. I'll be sure to look there.
    Sergeant:
    Champion:
  • 259 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Posted on Jan 26, 2009
I have armor command but can't get it to work on xp sp2 despite trying every setting combo in the compatibility window. how do i get it to work?
WinXP SP2:I've tried other systems too with no luck either. However, I've had this working (almost properly = every once in a big while it would hang and reboot was the only recourse) using an Intel D845GEBV2 motherboard with a 2.0GHz intel P4 w/ 1GB ram. I've found that the trick is the AGP card. The system stayed up long enough to play for hours. I had a Rosewill AGP Radeon ATI 9200SE video card. Apparently the 'rage' :) was AGP at the time this game hit the streets (1998) and this game is very AGP touchy.
I've also tried to run this on my P4 641 OC to 4.0GHz with 2GB ram with a Sapphire Radeon 9600 Atlantis AGP 8x video and ... no go. Similar issues with hand and config.
Right now I have it working on a just built Seattle 2 PII 440BX ATX motherboard (aka MICRON PC). It has a PIII @ 650MHz and 768MB ram. Boot to MS-DOS or Win98SE2. The video card on this one is an ATI Rage Mobility-L. A dinky little card, you can find one easily on EBAY for really cheap, but mine (bought on EBAY years ago for like $48) was out of an older MICRON system (not this Seattle 2 MB). Works fine. Really had to look on web hard to find a video driver for it ...This config also works great for these DOS games that I miss ... DOS Protected mode box within Win98 works perfect for Commander Keen and the original Duke Nukem!
Sep 14, 2010 | Ripcord Games Armor Command for Windows
Serial joystick
have you try to configure it first on the control settings of the dos games before you start playing it..??
Thank you & pls post back..
May 07, 2008 | Microsoft SideWinder Precision Pro 2.0...
DEAR SIR I HAVE COMPAUTER HP COMAQ DC 7900 I WORK WITH SOME PROGRAM WORKING IN DOS .. THAN I NEED INSTALL DOS OPERATING SYSYTEM THE COMPUTER DON'T RESPON ... ALSO THE COMPUTER DON'T HAVE LPT I BRING CARD...
the best way to do this is probably use windows and run dosbox for windows. What it does is it emulates DOS and lets you run any program that requires dos. Because your computer doesnt have a LPT port. and nowadays only drivers for dos or newer operating systems come with the card. installing the driver in windows then running dosbox, it will see the LPT port.
you can get it here
http://prdownloads.sourceforge.net/dosbox/DOSBox0.73-win32-installer.exe?download
May 04, 2010 | Computers & Internet
I need to know if I need a patch to run DOS applications.
Legacy DOS no such luck either you have corrupted files or a buggy version of program ie DOS 4 was buggy and Netscape 4.7 was also buggy . Advoid Windows 9x O/S 95 had the blue screen of death thats why I use over 2K O/S
Apr 16, 2009 | Computers & Internet
I have inno3d gfx5000 256mb agp card,,, but is can not run run call of duty 4. it show error... Error-Vid Card doesnt support Alpha Blen ... All it states is that glow will be disabled
If that video card doesn't support the open-gl format then it will not be able to run call of duty 4. I'm addicted to this game and had to upgrade my video card to play. I believe ATI still makes an agp video card that will support the game. Here's a link to the card: http://www.amazon.com/Sapphire-Radeon-HD3850-512MB-Graphics/dp/B00145CQUC/ref=dp_cp_ob_e_title_1
Hope this helps & please take a moment to rate this solution. Thanks.
Mar 12, 2009 | InnoVISION Multimedia Technologies GeForce...
Dos problem with sound maker value 5.1
Go to DOS prompt.
Enter SYSINF
If it works (shows info), then direct screen-output to a text doc.
sysinf>drive:\folderpath\filename.txt
Drive, folder path and filename are your variables.
Footnote:
I used MSDOS many years ago, so my memory of the command name is SYSINF but not 100% guaranteed it is.
May be sysinfo.
Try entering HELP at the DOS prompt which will list all available DOS commands.
Once you have your resulting text-file, view and / or print it.
Look for IRQ conflicts, problem areas, drivers and so on....
Happy hunting !! :)
Apr 13, 2017 | Genius Soundmaker Value 5.1
Formate
try to format it in DOS mode.
go to start
click Run
in DOS mode window, type "format" with the drive letter of the USB
also can you tell me the error message?
Oct 27, 2008 | HP RADEON 7000 (32 MB) AGP Graphic Card
I need to download a program that requires windows and my computer says the program wont run in dos mode how do i get it to work?
if the program requires windows that means it was design to work with windows and not with DOS.. you may want to get an old version of the program that will actually run under DOS.. usually you may be able to do the opposite which is to run DOS program on windows.
if possible try to get a DOS version of the program you are trying to run, or better.. upgrade your operating sytem so you can run your program and possibly other DOS programs.
post the program you are looking to download and confirm what operation system you're running and I'll try to look for it with you.
Sep 27, 2008 | Acer Computers & Internet
Blank White Screen.
cpu restart after first log on
Sep 06, 2008 | Sapphire RADEON X1550 Graphic Card
Opengl
Mx 400 dos not support openGL try running your counter strike in hardware or software mode that sould inprove game play
Nov 21, 2007 | Palit Microsystems GeForce FX5500, (256...
Diablotek RADEON 9550 Video Card - 64MB DDR, AGP 8x, DVI, VGA, TV Out, Video Card Graphic Card Logo
62 people viewed this question
Top Diablotek Computers & Internet Experts
Donna Sander
gaucherre
Are you a Diablotek Computer and Internet Expert? Answer questions, earn points and help others
