Question about Kenwood KGC-4042A 5-Band Car Equalizer
Which wire is power and ground
I bought a used EQ but the power wire isn't the original wire, I need to know which wire is power, which is ground, and what the third wire is for. Picture of the power wire the way it is is available upon request, and I would glady accept as a solution a picture of the original power wire.
    New Friend:
  • 83 Answers
Generally red is the ignition wire, black is ground, orange is 12+ all the time, a yellow could be the same....it would be more helpfull if you would give the model number of the eq
Posted on Jul 20, 2007
No problem. just bought it and a pair of thump 15s what cables are best. and we want to play our accoustic gigs through this and dont know how to set eq i know its different each room but a starting point.
Use balanced lines for the audio interconnects. Use XLR low noise mic cables or TRS type cables. IMPORTANT: Power the speakers and the mixer from the SAME receptacle, even if it means running extension cords. Ground bounce in building wiring can destroy the circuits in the equipment.
Jul 11, 2011 | Mackie ProFX12 Professional Compact Mixer
RADIO CUTS OFF WHEN VOLUME IS TURNED UP
It could be your wiring as well. Sometimes, when speaker wire gets cut and grounded, like your factory wiring to your door speakers or you tap into facrotry speaker wires to add more, the load on your deck increases. When the volume gets to a certain level, it will cut off because of the heat produced to maintain the load.
Feb 23, 2010 | Pioneer DEH-P4000UB CD Player
My high end stopped working in both my speakers
First thing is to run a known signal from a simple device like a small CD player to verify the problem.
If these are driven from a mixer, the EQ could be set to kill the highs.
Assuming it isn, something simple like an EQ setting, probably the units will have to be serviced. I know you would already have checked the EQ on the back of these things as a first step.
Remember to ALWAYS power these from the same source as the devices connected to them to avoid ground loops and damage.
Supersonic feedback can fry these. Oscillations higher pitch than you can hear can put too much power into the tweeters of these.
Nov 18, 2009 | Mackie MR5 MR5 Reference Monitor
I have a 300 watt amp, but i just bought 12 gauge wire why wont it allow sound to come from my 12'' sub
There is no reason even if the wire was to small it would still allow ssound.make sure you have good connections.
Nov 08, 2009 | Pyramid 906 300 Watts (peak) 10 Band...
Wiring ID- Pyramid SE808ECHO 200watt amplifier/grapic equalizer
THE UNIT YOU ARE USE HAVE SPEAKER IN AND OUT WIRES LOOK AT THE INSTRUCTION AT THE BACK OF THE EQ AND DECIDE HOW YOU WANNA USE THE EQ
Aug 01, 2009 | Car Audio & Video
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Power connection
look at the back it should show you
power, ground and remote
Jun 05, 2008 | Kicker 03KQ9 9-Band Car Equalizer
Kenwood KGC-4042A 5-Band Car Equalizer Logo
514 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
