Digital Rreceiver problems
The DUB-2850GB
S/N PT68BOU 1072
MADE IN EUROPE DMP4535200
FAULT WITH TRANSMISSION IN CERTAIN AREAS ONLY WITH DUB-2850GB BUILT IN FREEVIEW RECEIVERS
I HAVE JUST HAD A BRAND NEW AERIAL AGAIN WHICH IS NOW GS14 INSTALLED BY EVEREST TV AERIAL CO / VIEWTEC LTD, NOTTS.
IT IS SAID THAT IT IS A SOFTWARE PROBLEM AND I AM HOPING YOU CAN HELP ME SOLVE THIS PROB. THANK YOU
BARB EDWARDS. EMAIL:bibiedwards@aol.com
Tel: 01978 350470
  • bibiedwards Jan 25, 2009
    There is a slot in the back of the TV for a 1G card which I do not have but hopefully added software to resolve the problem will be send to me in card form for me to slot into the back of the TV. At the moment the Install on the menu is grey colour (indicating that this feature cannot be used) so I may need the card?
    Thank you
  • 19,396 Answers
Let us know if you received your 1G card, and let us know if this solved the problem.
Thanks.
Posted on Jan 26, 2009
  • 818 Answers
Please download the guide from here.
http://www.devicemanuals.com/guide/Television/Daewoo/Daewoo-CRT-TV-DUB-2850GB-(ENGLISH)-User%27s-Guide-TVRjd056QT.html
see if this can be explain your problem.
Sergio
Posted on Jan 25, 2009
URC11-2940 R00
0038.0033,0037. Try these codes. If you wish to get more; check the sites linked here. Both the sites have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Feb 02, 2014 | Universal Remote Control DIRECTV Universal...
Whats the lock key for deawoo DUB-2850GB
If it's the parental lock you are talking about try 1,2,3,4 When the parental block comes up hit play, enter 1,2,3,4, then hit play again. Give that a go.
Jan 25, 2012 | Televison & Video
What should be done if car is telling you, "transmission fault?"
TRANSMISSION PROBLEM IS JAGUAR DEALERSHIP FIX YOU HAVE TO SEE WHAT TRANSMISSION CODE YOU ARE GETTING.CHECK TRANSMISSION FLUID LEVEL MAKE SURE ITS NOT LOW.
Aug 20, 2010 | 2000 Jaguar S-Type
Подскажите,...
Regular reset: go into the menu and find "reset"...follow the on-screen instructions. Manual reset: remove the card and batteries...press every button...leave it alone for 20 minutes...insert the card and then the batteries...turn it on. You mentioned damaged firmware. Do you mean you attempted a firmware download and something went wrong?
Aug 17, 2010 | Olympus FE-330 Digital Camera
Code E0004 how to reset it?
You it is necessary to avoid the fault a thermo block, will be a questioning sensor and the temperature and code to faults will not appear. While exists the fault fuse you do not throw the code. He points to the source of the problem. You should apply to service. Given fault there is серъQзная problem for specialist under repair, requires the knowledges and adjustments. Good luck!
Oct 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Indicator light shows and i lost the manuel so i don't know what's wrong. i think its the drum but don't know. it won't work now
Hi! Yous problem is CH blinking? Dev unit is not properly installed...Or yous master unit is need to change to another.
The Main problems копиров AL-1000, 1631:
# optics and lazer
- a soiling the white band under left lid, fault E7-04
- a soiling the defensive lens of the block of the lazer, residing on drum; the near edge of the picture leaves light; remove драмом and neatly wipe lens, вычистить отработку in cartridge (is rammed bunker, and отработка is sprayed on lens) # presenting
- does not take sheets from pallet: faulty **** of the seizure or solenoid, openning ****
- an offset of the front edge or застревание papers on sensor of the registrations - is polluted sensor, faulty **** or her(its) solenoid, has weakened spring of the ****
- a crackle in region of the presenting - a roller to registrations left with its place and was displaced to the right # stove
- an senary bursts because of strong load (NGERH0540) of the teflon gross or is broken off her(its) internal salient
- an internal ring бушингов gains ellisic type because of uneven load on them that changes the pressure of the teflon on silicone; as effect, can be swabbed imprint or in general sheet remains in stove
- a finger of the branch on silicone are executed in the manner of tin-plate plate, and sooner cut the furrows on silicone, than execute its function - take away the plate under the first possibility - also standard fault H4 cleares out the code 14 (if thermostats does not work, possible, in him залипли contacts; then it is enough his(its) remove and enough powerfully knock on something - a contacts disperse)
- a sheet stops after passing of the stove - left with its place roller, taking sheet after leaving from stove because of breakage of the near fastening the roller (is found on block of the lazer, and access to him only after removing lid, main board and table optometrists)
- also comes out of building (is polluted) sensor output from копира - a main ajestment of the problems nearly does not create, with the exclusion of шестеренки, providing in motion stove (disappear teeth) # power supply unit - most often flies Q1 # коротроны
- upper in the event of contamination gives uneven thickness of the band on отпечате (remove, wash with soap and высушить)
- трансфер - gives the weak imprint; почистить brush, зачистить copper contacts in копире and contact springs коротрона little sprain # call attention: under wrong installation байпасса (the bypass pallet) iron fastening his(its) mechanism begins to brush against редуктор, heard crackle # фотобарабан rather sensitive to condition red bracket; their advisable change together with drum, otherwise appear the white bands on edge of the drum and white gaps on imprint # is sometimes overfilled bunker отработки, and toner is thrown outward, polluting upper corona and defensive lens of the block of the lazer.
Sep 24, 2009 | Sharp AL 1631 Copier
I change the laungage of my ipod now cant read it
Доброй ночи, Саша
Аленка
До свидания, Олег
hasEML = false;
Aug 29, 2008 | Audio Players & Recorders
Error 0X5b
Такая же фигня. Фотал нормально. Отключил автофокус, потому что фотал летящих птиц. Две фотки сделал и на третьей выскочила ошибка Camera errop code 0x58 . Выключение и вытаскивание аккумулятора не помогло. Вкл/выкл. автофокуса тоже. Не знаю, что делать. Завтра понесу в сервисный центр сдавать. :( Грустно.
Aug 08, 2008 | Sony Alpha DSLR-A100 Digital Camera
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
