Question about GE Monogram ZFSB26DRSS Stainless Free-Standing Refrigerator with Dispenser
ZFSB26DRSS water dispenser stops working.
The water dispenser stops working. I reset he filter but it did not help.Replaced new filter. Can someone help me? Thanks.
catriver
  • 878 Answers
SOURCE: Water dispenser problem?
grandfunk, by your post, it sounds like the line is frozen over. You will have to do some tests. First rule out the dispenser itself. While someone is calling for water see if you have 120V to the water valve. If you do, we ruled out the dispenser. Behind the toe panel there should be a water line with a john guest fitting going up the door. Disconnect it there and call for water. Catch it with a cup. If the water is flowing there, you might be frozen up in the door. I have found a couple of these models with that problem. If it's not flowing there, behind the lower drawers in the refrigerator section is the water coil tubing. Take a hair dryer and go over it lightly. It could be frozen over there. Check these things first and post back. Catriver.
Posted on Mar 19, 2007
the dr
  • 447 Answers
SOURCE: water dispenser won't work
see my posts in my solved solutions on water line freezing. I can email you a bulletin for a heater kit.
Posted on Dec 06, 2007
SOURCE: The water dispenser in my frig stopped working
Hi, Guys, There are three solutions to this problem:
1) Using a hair blower to warm the other side of the freezer door-----i.e. at where water dispenser is located; This may take 3 to 5 minutes;
2) Take out the filter, pour out the inside water, then fill in with hot water (really hot), then put it back on. This needs at least 24 hours to work
3) Turn on the light near the water dispenser, and keep it on for at least 24 hours. The light heat may eventually de-freeze water dispenser tube.
I tried methods 2) and 3) together. It took 10 hours to get water flow again.
Important: I need to point it out that the credit be given to other posts addressing the same problem at fixya site, though of different GE models.
Posted on Mar 03, 2009
  • 13 Answers
SOURCE: Monogram water flow problem
common low flow is a kinked line or a bad water valve, the solioid valve has a filter that may be dirty. then go from there
Posted on May 03, 2009
woodchuck789
  • 4059 Answers
SOURCE: water dispenser will not dispense water
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Posted on Sep 30, 2009
Hello, I have a frigidaire side by side fridge and freezer ( LGUS2642LF2). Water stopped coming out of the dispenser and the ice cubes are coming out but is taking a very long time. I first replaced the...
Good Morning Friend,
I understand that you are having trouble with receiving water out of the dispenser area of your Frigidaire refrigerator, model# LGUS2642LF2.I also see that you have changed the water filter as well as checked and replaced the inlet valve with no positive results, other than it sounds like it wants to dispense water and makes a humming sound. I suggest resetting your refrigerator, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power has been restored, try getting water out of the dispenser. If you are still having trouble, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of your refrigerator not dispensing water. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Frigidaire Refrigerators
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
Maytag refrigerator water dispenser not working
you may have dislodged a sensor or perhaps you may have blocked your water line somehow... im not sure about this specific model, but just try having a look at what you did and see if there are sensors around there.. and make sure u havent dropped anything in there wich may have clogged the lines... lets hope its not your solenoid that has gone, sounds unlikely though you never know
Nov 11, 2009 | Maytag Freezers
GE Monogram ZFSB26DRSS- water dispenser problem
Disconnect the water line at the water inlet valve on the back and try the dispenser to see if water comes out there and see if you hear the valve work. If the water comes out here then the problem could be the filter. The mesh screen in the water inlet valve could be stopped up. Disconnect the water supply line to see the screen. You may have to remove the cardboard backing to see the valve on the back of the freezer.
Oct 05, 2009 | Refrigerators
New filter but water dispenser still not working
Check the water valve if its working most probably watewr line inbetween the water valve and the water dispencer is frozen. Un plug the refrigarator for four hours and try again.
Mar 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
Nov 12, 2006 | Amana ARS9265B Side by Side Refrigerator
GE Monogram ZFSB26DRSS Stainless Free-Standing Refrigerator with Dispenser Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
