Question about Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder
RESETTING CAMCORDER EVERY TIME I TURN ON MY CAMERA A BLUE SCREEN COMES UP TELLING ME TO RESET IT.THEN ITS GOOD TO THE NEXT TIME I TURN IT ON,THEN THE SAME THING ALL OVER.IF YOU DONT HAVE A PEN TO RESET,YOUR SCREWED. THANK YOU
  • Anonymous Mar 15, 2009
    I have the same problem only now after I reset the camera I get the same message again in about 5 sec.
Try getting a new tape or if that doesnt work then i dont know i would get a case big enough for the camera and put the camera and pen in there
Posted on Mar 14, 2009
I have the JVC digital minidv camcorder, Model No. GR-D270U an it keeps telling me it's in safety mode and I can't even get the tape out beause the door opens but it's like the mechaism to pop...
After trying the remove-and-reattach-battery exercise, I would suggest you go to the menu and find the setting for initial setup. Select that - which may reset the system.
If not.. then try going to the clock and change the date/time settings, turn the camera off, remove-and-reattach the battery. Re-power the camera, go back and change date/time setting to what's current. And try to eject the tape.
On one of our analog video cameras it seems like there was a tiny little hole someplace on the side of the camera that you could use a tiny small thing like a toothpick to press in there to accomplish a Reset. (It will have tiny raised letters saying "Reset" right beside the little reset hole.)
May 16, 2011 | JVC GR-AXM270 Hi-8 Analog Camcorder
No playback after recording
check if you are using with a full battery..
if yes reset the unit and try again..
To reset the Camcorder, remove the battery from the Camcorder, press the Power button for 30 seconds and then reinsert the battery in the Camcder.
Dec 12, 2007 | Sony DCR-VX2000 Mini DV Digital Camcorder
I have C:31:22 on the screen of my camera. The screen is all blue. When I took out the tape a black wheel came out. What should I do?
I'm sorry that the camcorder displays the error: C:31:22. The error indicates that the camcorder has detected an issue that may require a power reset.
Follow the steps to reset the camcorder
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
If the issue is not resolved service will be reqired. Initiate service at:
http://eservice.sony.com
Dec 12, 2010 | Sony Handycam DCR-TRV840 Digital Camcorder
Can't turn off nightshot on my handycam help!!!
Option 1:
Using the NightShot:
1. First Set the POWER Switch to Camera, Slide NIGHTSHOT to ON.
2. The NIGHTSHOT indicators flash on the screen.
3. To cancel the NightShot mode, Slide NIGHTSHOT to OFF.
Option 2:
1. Let us try to reset the Camcorder and check if it helps to resolve the issue.
2. Locate the RESET button behind the LCD screen of the Camcorder.
3. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
Good Luck!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Panasonic PV-GS39 -- Eats Tape, Reset Button, Playback Problems
ya sounds like a bad tape loader. your estimate sounds about right. tape sensors also go bad so I would have them check it also.
Jun 01, 2009 | Panasonic PV-GS19 Mini DV Digital...
Head cleaning.
same problem in SHARP camcorders.
SHARP offers no satisfactory solutions.
Possible SHARP does not even manufacture a head cleaning tape.
If they do it is TOP SECRET.
I will never buy SHARP again.
Dec 22, 2007 | Panasonic PV-GS250 Mini DV Digital...
How to reset the camcorder if the reset button will not reset it.
...and try this first...:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
Jul 14, 2007 | Panasonic PV-GS39 Mini DV Digital...
Struggling with jvc camcorder GR-DX67
replace the fpc wire which is coming from the lcd unit to main board assumbly
Jun 24, 2007 | JVC 580136 Camcorder
Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder Logo
222 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
