Question about Apple iPod classic MP3 Player
UMSboot for ipod classic - Apple iPod classic MP3 Player
How to remove the screen lock
Where did all the lovely music go? When your iPod Classic freezes up, you may need to restart or reset the iPod. Follow these steps to reset an iPod Classic, or in fact any iPod with a Click Wheel.
Make sure the iPod Classic isn't simply paused or locked. Check the screen for a lock symbol. If you see a lock, unlock the Hold switch. You should be back in business. Put the iPod on a flat surface to stabilize it. Slide the Hold switch on, then slide it off. Hold down Select and Menu together for several seconds with two fingers. Make sure your finger isn't touching the Click Wheel. When the Apple logo appears, release Select and Menu. If the iPod Classic doesn't reset, repeat the above step. If that still doesn't get your iPod Classic to restart, plug the iPod into a power adapter or a computer and see if it starts up.
http://support.apple.com/kb/TS1382?viewlocale=en_US(URL)
Apr 17, 2013 | Apple iPod classic MP3 Player
Ipod classic has software issues
Dear sir or madam,if you are having problems with your iPod classic i would recommend plugging it into your computer, opening iTunes and clicking on the restore button. If you continue to have problems with your iPod classic take your iPod to your local apple store with a genius bar appointment already set up and they will help you furtherI hope this helps and that you fix your iPod
Apr 09, 2012 | Apple iPod classic 6th Generation Digital...
How can i reset my apple ipod classic?
This link to the apple support site will help you
http://support.apple.com/kb/HT1320
Feb 21, 2010 | Apple iPod classic MP3 Player
Ipod fell in water
Open the iPod classic and clean and dry it out as much as you can. Here's a guide on how to disassemble an iPod classic. Maybe a tech savy friend can do it for you. If you want to pay to have a service do it for you there are third party iPod Repair Services.
Jan 21, 2010 | Apple iPod classic MP3 Player
How can i listen to radio with my ipod classic 120gb, ill appreciate it thank you
Yes you are correct. You could listen to Radio on iPod classic 120GB.You can listen to radio using the optional iPod Radio Remote accessory for iPod classic.iPod Radio Remote attaches to iPod classic using the Dock connector cable. When you’re using iPod Radio Remote, you see a Radio menu item on the iPod classic main menu.
You can also look at the manual that would have all information. You can View it from :-
http://manuals.info.apple.com/en_US/iPod_classic_120GB_en.pdf
You need to have Acrobat Reader to view this.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | Apple iPod classic MP3 Player
My ipod has a circle red x on it and wont respond
First try resetting the iPod. If this does not work then restore it.
To RESET IPOD: 1 Toggle the Hold switch on and off (slide it to HOLD and then back again). 2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
To RESTORE IPOD To update or restore iPod classic: 1 Make sure you have an Internet connection and have installed the latest version of iTunes from http://www.apple.com/itunes/download/?ipod 2 Connect iPod classic to your computer. 3 In iTunes, select iPod classic in the source list and click the Summary tab. The Version section tells you whether iPod classic is up to date or needs a newer version of the software.
In Restore all data is erased from iPod classic, including songs, videos, files, contacts, photos, calendar information, and any other data. All iPod classic settings are restored to their original state.
Jul 19, 2009 | Apple iPod classic MP3 Player
TMR-BT8iP not working
this was made to work with any older genegarion ipod that works on firewire power not usb
most ipods
this is not fully compatible with the new iPhone,iTouch new nano and the ipod classic
May 07, 2009 | Sony Bluetooth Wirleless Transmitter for...
DIFFERENCE BETWEEN IPOD CLASSIC & IPOD TOUCH
Ipod classic has at least 2 to 3 times the capacity of ipod touch.
Ipod touch is touch screen and has max 16gb capacity
whilst ipod classic only has click wheel.and is like 60gb or something.
ipod touch is the iphone but without the phone bit,
May 30, 2008 | Audio Players & Recorders
Problem with ipod classic
Try this. The website will lead you through the most likely solutions.
http://www.apple.com/support/ipod/five_rs/classic/
Apr 17, 2008 | Apple iPod classic MP3 Player
Apple iPod classic MP3 Player Logo
213 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
