SOURCE: Diplomat dishwasher blows fuses
I would disconnect the heater then run the unit.If it runs the heater is bad,if the fuse blows again the motor is most likley bad.make sure there are no water leaks.let me know.happy holidays
SOURCE: Element Needs changing Bosch WFO2466
you should never have to remove drum to replace element. not familiar with this machine take back off and have a look or it will be at the front of machine
SOURCE: macine trips breaker between steps 2 and 3
It sounds like either the heating element is faulty (needing replacement) or the main motor is worn-out and needs replacement.
The only way to tell is to see which part is working correctly.
SOURCE: Hi David here.My washing machine
You will need to see the voltages to the sections , the spin, the drain and then confirm if the voltage stops from the program controller or the motor by itself.
If program controller stops action , check all inputs, check thedoor switch, check the connections, check the board.
If not the error canbe the board itself.
