Question about Buffalo Technology TeraStation Home Server (HS-D1.0TGL/R5) (E171512)
Buffallo terastation i lost my terastation admin password.give me a solution to reopen my terastation.
You can also contact Buffalo Tech and they have a tool that they can send you to install and then it will allow you to reset the password. :)
Posted on Nov 05, 2012
How can you loose the password? if your that stoopid then i think you shouldnt own TS,or is it you have bought second hand only to find its password encrypted? either way if you cant read then you shouldnt own a TS instead why not see if you can swap for an external HD ;D
Posted on Apr 02, 2009
How to change wifi password on Buffallo AirStation WBR2-G54 router
I'm not 100% sure, but I think the password is actually programmed into the bios of the router, so you can't change it...could be wrong. If someone is using your router, they must be aware of your password, remove the password sticker off your router and keep it in a safe place
Nov 24, 2013 | Computers & Internet
Tip
Buffalo Terastation
No need to enter Username and password in vista everytime you boot the computer
you can blame the security setting in windows vista -these decide the request /response authentication protocol used for the network login .The default setting for win vista NTLMv2 (NT lan manager version 2)
but the terastation still uses an earlier version of it .
The setting can be changed as follows :click tge start button ,enter "secpol.msc " in the search field and double click the progrma found .confirm the start of the console with "continue' .Finally ,double- click and open "security settings".then expand the "local policies" "security option" folder .In the following list select "Network security :lan manager authentication level".A dialog box open on double clicking it .At this point,switch to the "local security setting" tabthe default set option "send NTLMv2 respone only " to "send LM & NTLM -use NTLMv2 session security.if negotiated " .save the changes with "ok" and teraStation will start working again
on Apr 24, 2010 | Computers & Internet
I lost my pin
If it is the pin of your encrypted wireless connection (WEP/WPA etc.) then go to router's login page , usually 192.168.1.1 and then login using your admin username and password. In case you had not setup the router yourself then try the following username password combinations :
Username : admin password : admin OR Username : admin password : password
If you are able to login , then you can simply give a new password to your wireless connection . Exact instructions for doing so vary with the make of the router . In case if this doesn't work then you can try doing a hard reset of your router by pressing the corresponding button . Check in the manual of your router for doing so . In case you don't have the manual , then post the Model Number / make of the router or try searching for the manual on the internet or post back the model number for more detailed instructions.
May 09, 2011 | Computers & Internet
Lost my key password for belkin g router
there is a small reset button that u will need to push with a pen. Its usually to the back or side of the router.
Just jeep pushing it until the router resets then use the default username and password.
defaults. (normally)
user name - admin
password - admin
username - Admin
password - admin
username Admin
password Admin
user name Admin
password (blank)
username admin
password blank
look in your manual for the default username and password and instructions on how to reset.
Feb 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I forget administrative password, We have user account which is accessible by me. How can i give new password to administrator
you cannot give a password to administrator. But you can create another user with administrative previleges and you can delete the older administrator.
Sep 01, 2009 | Microsoft Windows Vista Home Premium with...
Lost Password
If you reset the router to factory defaults, then it SHOULDN'T have a password anymore, and if it does, it's probably something like:
Username : Admin
Password : Admin
or something like that, actually, it should just be blank. Try checking it's manual, as it may give the factory default username and password in there.
Jul 05, 2009 | Computers & Internet
Need to reset admin password on V3000
Default password is 0000. If you lost a password you set its almost impossible to retrieve.
Mar 26, 2009 | 3Com NBX® V3000 (3C10600BUS)
Lost my XP Admin name and password. So how do I hack it?
well hacking is illegal wether it is your own system or not i can not confirm.
best advise i can give you is see if the administrator account is on.
wich would most likely be :
username : Administrator
password :
yes password would be nothing.
if it works you can reset your password of your own account
good luck
Feb 14, 2009 | Dell Inspiron 531S (DDCWGA1_5) PC Desktop
Lost Admin Password Windows Vista
I am not sure what you mean by you lost your admin password.
It does sound to me that the only solution is to format and reinstall though.
Nov 11, 2008 | Microsoft Windows XP Professional With...
Lost admin password for ricoh aficio 3260c.
if u have bios password u shoud do that remove your bios battry from the motherboard for few mints & your password will be reset
Jul 16, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Buffalo Technology TeraStation  Home Server (HS-D1.0TGL/R5) (E171512) Logo
224 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
