Question about Janome Sewing Machines
Janome 9000 error message that thread is broken
Stops sewing and gives error msg that thread is broken when it is not.
bargainbox
  • 1388 Answers
SOURCE: Janome MC 9000 Embroidery/Sewing Machine
This is the diagnistics routine for Janome 9000.
Run each test in sequence from 1 - 13, or until you find error
The results of this may not be what you want to hear, and may be why no-one has yet replied....I hope for an easy resolution for you
If you are having trouble reading this here, simply send a request via the "contact us" page on:
www.bargainbox.com.au
Martyn
Posted on Feb 16, 2008
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 192 Answers
SOURCE: Designer One "broken thread"
If the upper thread spool is spinning allowing slack to the inlet of the tension assy and the machine gives a broken thread indication shortly afterward, the pre-tension assy needs to be adjusted. If the machine has the original "snap in" tension assy that was in the first generation of Designer 1, have it replaced with the modern "lay in" tension assy. Slack at the spool should never cause a broken thread indication as long at the thread is in the pre-tension assy.
Sulky thread will work as well in a Designer 1 as any other embroidery thread as long as it is properly adjusted.
One thing that you can look for, when the machine is sewing, watch the thread as it passes out of the left hand side of the tension disks. It should exit the disks at the 9 o'clock position. If it starts to drift up to the 10 or 11 position and then you get a broken thread warning, the pre tension must be increased.
Posted on Apr 08, 2008
louislevel_2
  • 374 Answers
SOURCE: How do I thread my Janome
hi! there,
how to threade your janome well, just click this to internet on youtube you can learn much more i thought you, you can rely on this one.doing this type www.youtube.com then on youtube search type jonome sewing machine and it will find it for you how wind bobbins and how you thread sewing machine.try to watch and enjoy watching and more interesting you will learn.have a nice day
dont forget to rate me.
Posted on Apr 09, 2009
SOURCE: i have a janome 9000 what is a scan & sew
Scan 'n Sew is hardware used to transfer embroidery designs from your computer to the machine's card so that you can embroider that particular design. I have one and love it. It will send a template to your printer as well as the design to the card. It has other functions that I don't use because I use another program to edit designs (Embird).
Posted on Jun 10, 2009
Help re. error msg C6. Manual says my top thread is broken but mine isn't.
could be a problem with the sensor giving the wrong signal, the sensor may have to be checked
Oct 01, 2015 | Singer One Plus Computerized Sewing...
Janome 8100 manual
The bobbin thread on my Janome 9000 is showing in the stitching. The bobbin thread pulls over to the left when sewing a zig or multi zig zag stitch. What to adjust?
Jun 11, 2014 | Janome Memory Craft 9000 Computerized...
Janome 9000 thread frays and breaks
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
May 29, 2012 | Janome Memory Craft 9000 Computerized...
My machine janome 9000 acts like it wants to sew then it stops and locks up I have checked the bobbin thread and it is not stuck
then something is either worn or broken in the mechanical part of the machine or a part of the computer is messed up,, it needs to be serviced
Feb 28, 2012 | Janome Memory Craft 9000 Computerized...
My sewing machine model no 9000 is showing a error is '' raise the pressure foot and needle bar then power on #01
First, I would make sure the embroidery unit is unplugged if you r trying to sew and check the bobbin winder to make sure it is off. Also look for thread in the guide, these machines are very sensitive and when the slightest bit of thread gets caught in the tension of the threading format, the computer will automatically turn on error message.
Sep 16, 2010 | Janome Memory Craft 9000 Computerized...
Error; after checking bobbin threads, press start button
This is most probably solved by an adjustment to your bobbin thread sensor, and not something for the home handy fellow......especially without a manual.
Be sure that there is no lint build up in or under the bobbin case as a first measure, and give this area a good clean anyway as normal housekeeping.....this will probably make little difference, but may let you finish any urgent job over the weekend.
When was your machine last serviced ?
2 years or more ?
When was your car last serviced ?
Your best solution is to take it to an authorised Janome Service Centre (make sure they have the Service Manual for this model) and make sure to tell them about the bobbin sensor issue so that it can be specifically targeted during a full service.
This MC 9000 was expensive and the top of the range in it's day and deserves good regular care to work to its optimum for many more years.
Jun 08, 2008 | Janome Memory Craft 9000 Computerized...
Janome 9000
I have a Janome 9000, was sewing and broke needle, replaced and broke another. I didn't have machine threaded, took out bobbin and would sew a little and stop saying thread broke. I took off top plate and started machine again, sew a little and stop saying thread broke. So I took out bobbin case and sewed again and stopped repeating the message. Everything looks OK, bobbin case and top plate. I guess I want to know if the timing could be off or do you think it is the computer part of the machine...Should I take it to the Sewing Machine Shop??
Apr 30, 2008 | Janome Memory Craft 9000 Computerized...
Janome 9000 willl not work when turned on
My Janome 9000 has always done that. I can prevent it by raising the needle when I first start the machine, getting it to sew quickly or raising the needle and letting the machine sit for a few minutes. I think my computer wants to warm up a minute. As you can see I.m not a technical person but it works for me.
Nov 16, 2006 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
